Weird lighting issues
Pathfinder-jay
Been posted many many times, its usually your rear hatch is not closing tight enough. Go in back and loosen the 2 bolts that hold down the metal latch hoop on the floor in the very back of the cargo area where the rear hatch closes, then try sliding it back as far as possible and tightening the bolts. Others have had luck wrapping some tape around it (temp fix) or adding a washer or 2 under the hoop.
