Steering stabilizer problem
ShadowManR6
so i got the steering stabilizer for my 87 pathy from 4x4parts, i have it installed and what not, but i notice that the end of the spindle rubs/bumps on the bottom part of the idler arm when i turn far far left and or hit a bump turning left, once i add the new upper control arms will that fix the space issue or make no difference. any ideas/suggestions?
Edited by ShadowManR6
using pic from statikuz post write-up as an example but in the pic towards the left side where the idler arm is, when the steering wheel is turned far left, the idler arm moves towards the spindle end of the stabilizer, and hits basically right onto the end, now it's only a problem when i hit a bump cause that'll cause a little bump and it'll hit the end into the idler arm. i haven't been able to put on the UCA's/adjust torsion bars, but not sure if that'll even make a difference
