4.88 or 5.13?
SteeevO
After the SAS on 35's should i go w/ 4.88's or 5.13's? i'll still be driving this on the street quite a bit so i can't take too much outta the top end for on the highway... where would your RPM's be doing 65 - 70 with 35's & 5.13's how bout 4.88's?
Personally I'd go higher numerically rather than lower. You'll have more torque to the wheels and it'll keep the engine working in a good RPM range. The only problem I foresee with that is matching gearing, a D44 can use 5.11's, which is close enough.
