SteeevO Posted March 16, 2007 Share Posted March 16, 2007 After the SAS on 35's should i go w/ 4.88's or 5.13's? i'll still be driving this on the street quite a bit so i can't take too much outta the top end for on the highway... where would your RPM's be doing 65 - 70 with 35's & 5.13's how bout 4.88's? Link to comment Share on other sites More sharing options...
Pavelow Leaks Posted March 16, 2007 Share Posted March 16, 2007 http://www.csgnetwork.com/multirpmcalc.html Link to comment Share on other sites More sharing options...
88pathoffroad Posted March 17, 2007 Share Posted March 17, 2007 Personally I'd go higher numerically rather than lower. You'll have more torque to the wheels and it'll keep the engine working in a good RPM range. The only problem I foresee with that is matching gearing, a D44 can use 5.11's, which is close enough. Link to comment Share on other sites More sharing options...
Mookie Posted March 18, 2007 Share Posted March 18, 2007 I'd go with 5.13's. This will get you close to stock - close enough to use over drive or 5th gear. Link to comment Share on other sites More sharing options...
