Gripenfelter Posted March 13, 2007 Share Posted March 13, 2007 Vacuum Cut Valve Bypass Valve. Does this mean my gas cap is loose? Link to comment Share on other sites More sharing options...
patzx300 Posted March 13, 2007 Share Posted March 13, 2007 No, it means the 4 way thingy "thats how us technicians talk about such things" probably needs to be replaced. I just checked asist and there is not a reprogram for the code. Link to comment Share on other sites More sharing options...
Gripenfelter Posted March 14, 2007 Author Share Posted March 14, 2007 Where is the "4 way thingy"? I cleared the code and it hasn't come back. Link to comment Share on other sites More sharing options...
Pavelow Leaks Posted March 14, 2007 Share Posted March 14, 2007 codes are sometimes flukes, but not usually, if it doesn't throw it again I wouldn't worry about it. Oh, and for future reference, I forgot the code, but loose gap cap usually throws a code for "small vacuum leak" Link to comment Share on other sites More sharing options...
5523Pathfinder Posted March 14, 2007 Share Posted March 14, 2007 Double check all of the hoses back at the canister. The vacuum cut valve is white with four ports on it. There is also a vacuum cut solenoid, make sure its plugged in. Probably a cracked line or port. Small evap leak I believe is a P0440. Link to comment Share on other sites More sharing options...
Gripenfelter Posted March 14, 2007 Author Share Posted March 14, 2007 Where is our evap cannister located? Link to comment Share on other sites More sharing options...
5523Pathfinder Posted March 14, 2007 Share Posted March 14, 2007 Look behind the left rear tire. Use a good flashlight. Link to comment Share on other sites More sharing options...
Gripenfelter Posted March 29, 2007 Author Share Posted March 29, 2007 Thanx guys. http://www.nissanhelp.com/Ownership/Bullet...2/NTB02-033.htm Link to comment Share on other sites More sharing options...
