Shocks for front and rear the same?
howlerman
I plan on doing the JGC rear coil lift and Roughcountry A-Arm torsion lift
My question is are the shocks the same for the front and rear, I will be replacing my stock shocks. :hide:
I looked over the forums and found the part numbers here;
http://www.nissanpathfinders.net/forum/index.php?showtopic=9988
Should I use the slightly longer shocks for the rear and stock specs shocks on the front? Or use the same on front and rear?
Thanks in advance to the Pathy gurus :bow:
:beer:
Edited by howlerman
They are not the same front and rear. That question would have been answered by simply looking.
Longer shocks in the rear are good, in the front they aren't necessary because the UCA's don't change the amount of travel your IFS has.
FYI.. in the past i looked at the specs of the Rancho RS5000's compared to the RS9000's... the 5000's are longer even though they are both called for the same vehicle and ride height.. so u'll get a lil more travel outta the 5000's
they've worked great for me too!
