KevinKernaghan Posted February 21, 2007 Share Posted February 21, 2007 I need to find a constant 12V power supply under the center of the dash behind the radio somewhere, to splice in some units for satellite radio. The cigarette lighter, apparently, isn't of this type. Anyone have any ideas? I guess if nothing else, I can do an add-a-fuse on the fuse panel...let me know if you have any suggestions! Kevin Link to comment Share on other sites More sharing options...
NismoSkyZ Posted February 21, 2007 Share Posted February 21, 2007 I routed mine throught the firewall and attatched it to the fog light relay. I'm sure there is an easier way to wire it IN the cabin. I don't reccomend wiring it to the cigarette lighter since that fuse tends to enjoy blowing. Link to comment Share on other sites More sharing options...
SteeevO Posted February 21, 2007 Share Posted February 21, 2007 one of the wires for you main stereo head unit is a constant 12v i'm sure if you look in the owners manual for the stereo it'l say waht color it is of the wires powering the headunit. i'd splice it off of there Link to comment Share on other sites More sharing options...
govols74n Posted February 21, 2007 Share Posted February 21, 2007 Just wondering.....why do you need continuous power for satelite radio? Or is it something else? Link to comment Share on other sites More sharing options...
mws Posted February 21, 2007 Share Posted February 21, 2007 Just wondering.....why do you need continuous power for satelite radio? Or is it something else? Probably to maintain memory. Link to comment Share on other sites More sharing options...
Pavelow Leaks Posted February 21, 2007 Share Posted February 21, 2007 If you don't have a manual..or are just lazy like me, get a test light and start checking wires, as said above, one of the ones from your factory harness is constant. or you can run a constant off the fuse box. Link to comment Share on other sites More sharing options...
KevinKernaghan Posted February 22, 2007 Author Share Posted February 22, 2007 I've got it, for now, running off of an add-a-fuse going into my dome light section in the fuse panel. It takes really minimal power to keep the memory active, so I don't think I should run into much trouble, but it does bug me that I had to go to this much trouble already. Oh well...it works! Link to comment Share on other sites More sharing options...
mws Posted February 22, 2007 Share Posted February 22, 2007 With practice, it gets easier. Link to comment Share on other sites More sharing options...
govols74n Posted February 23, 2007 Share Posted February 23, 2007 (edited) The reason I was asking is because I have serius and it's just plugged into the cig lighter and the thing doesn't lose memory....the stations automatically reload every time I turn it on via satellite.... once I program something into it it stays until I delete it... Edited February 23, 2007 by govols74n Link to comment Share on other sites More sharing options...
