stumble
89_trailboss
89 VG30I
truck starts great. runs fine when you granny it. have nice power. but at ~2500RPM I get a bad stumble/heavy hesitation(only when you are on the gass good). I can cruze the highway with no problem. but when ever I get on the gas I have this heisitation. So what I do Is jsut punch it and get it to down shift -- thus getting me out of the 2500-3000 range and my truck fine. unless your really heavy and then it stumbles at 3500 up.
this started when I was low on fuel. but I wasnt THAT low. I have been lower. so my first thogh was that I sucked somthign up into the fuel filter. swapped filters and still have it. maybe because im not running a filter? nope. put one in and the same thing happens. any idea's? Im thinking that my fuel pump is starting to kick the bucket.
well, fixed the fuel leaks. yes plural pssd
still have it. it seems to be getting worse-affecting more of my RPM range as this goes on. doesnt get worse when its cold or hot. same shhit no matter what. pissed cause I have a trip on sunday and I dont think im gona be able to wheel much with this problem.
ill clean my MAF tommorow. altho it was just cleaned 3 months ago. im going to put my old wires back on tommorow and see what happens. any way a fouled spark plug/plugs could cause this stumble/hesitation?
im going to snag a fuel pressure gauge tommorow and see if my pumps gone.
last time I check my codes(month ago) I had the ignition signal code(11 or 21 IIRC) and my dreaded 02 sensor code was back. if I have good pressure ill swap 02's but I dont think this is the problem.
possable vacuum issue? I know I put a slight crack in my PCV tube. but it wasnt anything that I worried about cause it was SOOOO small. and I put some RTV on the PCV to help seal and possable issue.
Im sure this is a fuel problem tho.
any other ideas?
it idles fine. jsut seems to chung under load. I cant pin it and the RPMS will go to say 4500 and stay there cause the trans is in POWER. when its just sitting at the said 4500 it runs fine. but any bit of gas it will stumble.
pulling codes as we speak. well, in a min.
Do not delete the MAF sensor from your list of suspects - what you describe is consistent with problems with it.
It's not sounding RPM related so much as an inability to correctly adjust fuel for changing air intake.
I agree. its not RPM related. from my past experense with other vehicals this feels like a fuel problem. my buddies B2 had very similar problems but his truck would stumble so bad it would stall. swap fuel pumps and it was fine. but eveybody on the web thinks its somthing else.
anyways, I pulled the codes and got 13 and 21. ive never gotten the engine coolent temp sensor(13) code before. always had the 21 tho. could 13 cause these problems? for some resone I think I heard about it causing problems. but I cant seem to remember if it was running problems or if it was removal on the VG30E motors that was the problem.
thanks for the help guys.
I think it could.
Basic concept of fuel injection: The ECU uses lots of inputs to determine how much fuel the engine would need under the conditions at this millisecond.
Then it looks at what the O2 sensor is saying as to whether it is too rich or too lean and adjusts the mixture closer to ideal.
Keep in mind that the feedback from the 02 sensor can adjust only so much.
So if ANY of the key sensors are faulty, they will give the ECU faulty information and it is going to squirt too much or too little fuel. So any sensor can cause a "fuel delivery" problem.
A faulty water temp sensor? If the sensor is telling the ECU that the engine is cold, the ECU is going to squirt a very rich mixture, and the feedback from the O2 will never be enough to make it right.
jesus christ. feel like a fawkin IDIOT!
so I had the stuble while driving but it would idle fine and would drive fine if I grannied it. in the prosses of finding the issue I replaced the Cap and rotor. as soon as I did this the truck had a heavy miss. I replaced plugs and wires AGAIN. still same stuff. MAF and coil changed AGAIN. still same thing. got pissed and left it today and went out for dinner. on the way to dinner it dawned on me. some how I managed to put my #4 and 6 plug wires on each other(4 on cap went to 6 and visversa). so I turned around and went back home quickly. swapped them around and sure enough the thing idle fine! and in the prosses of trying to figure out the rought idle I replaced somthing that fixed my stuble while driving. YAY!
Just in time for sunday wheeling.
one more thing tho. how many degrees is each timing mark?
