6"*9" side panel speakers
88pathylove
If you want to take the whole assembly out, there's a plastic strip at the bottom of the boxes, held on my little clips. Pull that plastic strip off and unscrew the box from the side panel, 4 screws. The box will come off of the wall, and you can unclip the wires, the whole assembly will come out. If you want to take just the speakers out, pop the top off of the boxes, and unscrew the 4 screw holding the speaker in.
There is an amp that powers the stock speakers, it's hidden behind the side panel in the back, passenger side IIRC.
