Pulled codes...
89_trailboss
finaly pulled my codes on my 89 VG30i. not as bad as I though it would be, but still... anyways, heres the damage:
11: Crank Angle Sensor/Camshaft Position Sensor
21: Ignition Signal
33: 02 sensor
02 will be replaced this weekend if it comes in.
now the other two tho... the ignition signal I have no clue where to look. only shop manual we have is for 94 and I cant find anything on it. but from the diagrams in the shop manul, the Camshaft position sensor is built into the distributor, and and the igniton coild is wired to the position sensor. so im woundering if fixing code 21 will help with 11. just a shot in the dark tho.
anyone have any clues on where to start with codes 21 and 11?
thanks alot,
Dallas :beer:
well after a quick seach, looks like distributor and the little black box beside the coil will need to be replaced.
but I also found a guy saying that he found JSUT the crank postion sensor. heres the info:
www.net-parts-express.com
part# NI036449
Made by FACET
Site says:
"Crank Position Sensor
fits O.E. Dist #'s 22100-16E00
22100-16E03
CRANK ANGLE SNR"
anyone have any thoughs on what I should do?
sounds like code 11 mixed with my 02 could be a cause of @!*%y milage,power, and rich smell.
also, my truck wants to stall upon first start(about first 1-2 min of start up) and has a good hesitation/almost miss sound at 3500-4500ish also almost stall when accelerating from stops. but only some of the time. some days its every stop, others it will never happen. any thoughs?
Edited by 89_trailboss
I have heard of people getting faults reads on code 11.. have you tried clearing the codes and running it to see if acts the same and if the code returns?
I have replaced the Dis. once.. not usually a cheap option :nono:
Edited by RedPath88
