Will these plugs work ok?
pvpathy
Came home with the plugs that Crappy Tire says are the correct ones for my 99 (early) Pathy.I know they are one heat range colder than stock...Anybody using these?
They are NGK BKR6EGP
Thanks!
Steve
NGK is backwards. That's one range colder. You'd have to measure the depth etc to make sure it's ok. It's the same basic plug, but the EGP makes something different on it. Colder is ok if you beat on it. If you don't get it hot enough it will foul more quickly. I'd just order a set from somewhere else. Are you in canadia?
