mishikwest Posted September 29, 2006 Share Posted September 29, 2006 (edited) The reverse lights on my 94' V6 are very intermittent...sometimes they even flash like crazy when going in reverese. It's behaving like a cruddy/out of adjustment switch or contacts. Anyone know off the top of their head where the revese light switch is? Manual tranny. thx Edited September 29, 2006 by mishikwest Link to comment Share on other sites More sharing options...
Simon Posted September 29, 2006 Share Posted September 29, 2006 It's mounted to the tranny, right near the transfer case....way up high if I remember correctly. Check the connections, though, as I had a problem with mine a while back, and I just disconnected, sprayed with electrical cleaner, and reconnected. All was well. Link to comment Share on other sites More sharing options...
keithb7 Posted October 1, 2006 Share Posted October 1, 2006 (edited) It's mounted to the tranny, right near the transfer case....way up high if I remember correctly. Check the connections, though, as I had a problem with mine a while back, and I just disconnected, sprayed with electrical cleaner, and reconnected. All was well. Good advise in cleaning the electrical contacts first, see if that fixes the problem. Otherwise getting at that reverse swith is not easy. I tried everything to get it out, I had no wrench in my large selection of tools, nor could I think of one I had ever seen. It is a very tight spot to get into with a wrench. I gave up and took it to a shop. I picked up a new switch from a UAP/NAPA store. Good luck. Edited October 1, 2006 by keithb7 Link to comment Share on other sites More sharing options...
Maz Posted October 1, 2006 Share Posted October 1, 2006 I broke mine with a hammer then slid the socket over it and managed to get it back in with a wrench. Still didn't fix my problem though. Something in the tranny isn't engaing the switch Link to comment Share on other sites More sharing options...
