geordie4x4 Posted August 2, 2006 Share Posted August 2, 2006 Believe it or not you can add LPG to a diesel. I just read an article in Australian 4WD Monthly magazine on LPG injection to a diesel. The results look good, 20% or more power and torque increase with better economy and cleaner running into the bargain. Have a look at this link http://www.dieselgas.com.au/home.htm Geordie Link to comment Share on other sites More sharing options...
Datsunman Posted August 2, 2006 Share Posted August 2, 2006 Wow, I've never heard of that being done before. Very interesting, especially as LPG is now widely available here. -Ed Link to comment Share on other sites More sharing options...
Harbinger Posted August 2, 2006 Share Posted August 2, 2006 Its nothing new, but its the first time I've seen it for anything other than the US domestic market. Heres a quick link I found in under 3 minutes of googling. Diesel performance Link to comment Share on other sites More sharing options...
Guest fascar Posted August 25, 2006 Share Posted August 25, 2006 Dear All, I have tried it on my jeep m38a1(with a toyota 2ct mated to its original drive train). Well it was ahome made setup for boost at 1500 rpm, MY GOD!! it give a good kick BUT push it too early and you have alot of knocking(seems like the engines gone) push it late and there seems to be no effect. This means we need to put in a gas flow regulator for variable rpm. My opinion would be to wait as this setup needs some further investigations(home made or otherwise). The diesels are poor burners only 75-85% of fuel is burnt. The plg replaces the unburnt fuel and makes a complete burn(bigger bang) as most of the fuel is burned there is little soot(black smoke). You can therefore reduce diesel flow to compensate(hence fuel economy). Here our motto is to improvise and go indigenous(imagine a toyota 2ct diesel engine mated to a jeep tranny) so I am looking for a regulator with a diaphram(as the lpg nozzle goes in the pre turbo intake as there is vaccum). By the way lpg has a higher ignition temp than diesel therefore under high pressure in the chamber the diesel would initiate burn and the lpg would quicken the rest of the process. I would be more than happy to write more if anyone out there is brave enough(I have withdrawn strategically---ahem!)As I really like my terrano a lot i would not try it on her. Fascar Link to comment Share on other sites More sharing options...
