TXPower
1993, V6, 5sp, 4dr, with 289,000 miles on it.
36-40
1993
Gender
Texas
Country
2,608 profile views
TXPower's Achievements
NPORA Regular (2/5)
Mr.510's VG33 Crank Adaptor.
TXPower replied to conor1123's topic in Solid Axle Swaps, Hardcore Custom Fab
I bought a crank adapter from Mr.510 from his eBay store about 2 months ago. I have it put up for now as I'm still getting all my stuff together for my VG33 swap. Between Mr.510's VG34 build thread and NissanNuts web page and questions answered by other members here you can get it all together. I'll be keeping my factory 93 oil pan, pickup tube and accessories as much as possible and will use the oil pump and filter mount from an Xterra because it relocates the oil filter and gives it a little forward angle to make oil changes a little easier. Having said all that, I'm in design phase but will post updates and what I learn along the way as I make progress in my swap thread in Members Rides section. TXPower -
88 Pathy 3 link front. 63" chevy rear
TXPower replied to BIGFINDERMAN's topic in Solid Axle Swaps, Hardcore Custom Fab
Solid work! TXPower -
Looks great! Is the CC one whole piece from where it surrounds the shifter all the way to the back of the storage compartment? I want to do this with my 93 SE when I do the interior stuff. TXPower
I was wondering the same thing, what do you do with the front? I figured 4.5" was beyond what a T-bar crank and aftermarket UCA's could do?? Thanks, TXPower
Yeah, ahardb0dy I saw that the beergarage rebuild was 2wd. The FSM shows both 2wd and 4wd models. Exploded view shows the differences which is mainly in the last section of the tranny case, before it mates to the T-case. TXPower
Can anyone recommend a supplier for MT rebuild kits from experience or a trusted source? The guy on the beergarage site mentions 2 but I was just wondering if any of our members had rebuilt their 5spd and could point me to a quality supplier? Thx, TXPower
Slartibartfast, that's what I was looking at too, the beergarage rebuild. I'm actually considering doing mind myself. I have most of the tools he used. I may have to make a few custom fab adjustments on pullers like that dude did and I think I'll go buy a 12 ton or bigger press. But yeah, I'm probably gonna rebuild mine. I'm not in a hurry, so I can take my time. Besides, the same tranny or a later model one from an R50 or other Nissan with 100k plus goes for a minimum 500 bucks round here. With like a 60 day warranty at most. I've got my dad for help and advice too, he used to rebuild Muncie and Saginaws back in the day. TXPower
Think I may have answered my own question looking thru my FSM but please confirm....... It looks like the FS5W71C was coupled with the KA24E, so earlier Pathy's? And my 1993 has the FS5R30A coupled with the VG30e, right? TXPower
Trying to figure out if my 1993 SE Model has the FS5W71C or FS5R30A Manual Transmission. Is there a badge on the tranny, something in the VIN or a way thru visual inspection to tell? Thanks, TXPower
The adjusting nut and lock nut on mine were at about the halfway point (maybe a little less than half, closer to the x- member) of the bolt from the top of the cross member to the tip. And from memory, I believe the rear anchors on both sides were inside the cross member or un-exposed for the most part like several folks have recommended. Oh and this is all predicated on looking from behind the cross member toward the front of the truck (as far as the rear anchor clocking), right? My rig wasn't sagging too much before I started working on it but I do plan on some aftermarket UCA's, cranked T-bars and JGC coils for a lift. That is unless I decide to not be cheap and buy a full boat suspension lift. Thx, TXPower
Ahardb0dy, so it doesn't matter what position the t-bars themselves are clocked, it's just matters where the rear anchors are clocked? Also the clock positions you mention, from ths FSM 4 and 8 o'clock that looking from behind the cross member toward the front of the truck, right? Thx, TXPower
Old thread I know but question. I took the t-bar, cross member and t-bars out of the front and rear anchors when I removed it all to get my tranny out. I marked them but.........the white-out I used got knocked off, so I'm not 100 percent sure where to clock everything when I go back together. Can anyone tell me a good place to start, that is, first, where should I clock the rear anchors inside the cross member? The front anchors are stationary so I guess next I need to know where do I clock or spline the t-bars themselves inside the rear anchors to make sure they are the same? Can I just pick an arbitrary spot, the same spot, on the Left and Right t-bar and insert into the rear anchors in as close to the same spot as possible on both sides. Or is there a certain mark and spot I should look for to use for clocking these and getting them back in correctly? Help needed, TXPower
Good info and write-up. Thanks MY1PATH, TXPower
MY1PATH, thanks dude, very informative. I won't be modding quite as much as you, I want to get some more power and performance but without pushing the outer edges of this things capacities. I'm leaning toward a 3.3 from a villager for obvious non-interference reasons and could see me supercharging it somewhere down the road. Maybe milling the head .050 but I want dependable power not to work on it 6 days a week and drive it 1 like I used to do with the SBC's I used to hot rod as a teenager. I'll be picking your brain more in the future. Thanks man, TXPower
Adamzan, rebuild or replace is yet TBD. I read that dudes thread on beer garage I think it was where he chronicles his tranny rebuild. I have the FSM and have some pretty decent mechanical skills but wow, that looks like a lot of moving parts and I just don't know if I'm up to rebuilding myself. So then the question is pay someone to do it? My hope is to find a decent used 5spd with or without the t-case, price depending obviously. If the price between paying for a rebuild which requires just synchros and maybe some bearings and purchasing a decent used 5spd are close and a rebuild comes with a better warranty, probably a rebuild. Unless someone legitimately can say rebuilding my tranny is a job that really is manageable and wants to encourage me and answer tons of PM's and phone calls while I'm doing it that is......... From advice on here I'm fairly certain I had decided to look for a donor 3.3 from the non-interference strain placed in the Mercury Villager, unfortunately, that plan rules out buying a 3.3 already attached to a 5spd tranny, like say from a late model Pathy or Frontier or Xterra. Still open to ideas. From the advice so far, I think my t-case is fine and serviceable. Thanks, TXPower
