jumper
Everything posted by jumper
  1. Nissan Terrano WIDE BODY 1995 link
  2. 2 of them claim to be wide body terranos the other is just wrong
  3. To the mods is there any chance of a diesel forum on here just to keep the diesel stuff together please
  4. hi dsb you will find there are only a few diesels on this site. i have a 92 td27t that is not stock any more, i will get some pics of the intercooler setup and where to turn the boost up.
  5. about the intercooler i got a used one for $70nz, rubber bends $50nz, 100mm of 3in alu tube off my unused nudge bars, free, 150mm 2in alu tube off an old light boom, free, hose clips $15nz that makes $135nz with $1565nz/au+/- left rear shocks cost me $180nz a pair is this about street or offroad?
  6. more like this snapped clean off
  7. who has bust a tie rod end ? where did it break? on the tie rod thread, on the smooth part of the rod, the joint or the tapered part and thread? the reason i ask is the first day my terrano is street legal i took it for a shake down run on a local coast track. all is fine no loose anything just need to trim more metal on the back wheel arch. second day went back on the same track to go fishing, got 3/4 of the way to the spot i was heading for ,which is a 50min walk over rough ground (*$%£),and was driving on a tiny pebble part of the track at about 25/30km when as i was turning right the truck decided to go left go out had a look and the left outer tie rod end had snapped on the smooth part this meant get a lift off the next truck to pass (5mins) he was good enough to tack me to the end of my road ,about 3.5km from the track, grab the old tie rod ends which should have been in the truck drive back in my other car then with the ends and heavy bits in a bag i walked back the (@£$%*^!) 50mins to the truck fitted the end and when fishing
  8. v6 - the only reason i was asking was to see if anyone had any tips , placement of the brain , siren, hiding of wires or anything else as i have not installed an alarm before and it does not have one. And as the cost of a pro woud be $200+ to get it installed plus $75-$80 for the door lock acuator jj - i have a 92' diesel TDt
  9. shoud i do it myself or get a pro to do it ? what are the tricks of the trade for the wiring ?
  10. who has the lowest price for arb lockers in the us ?
  11. the pics are on damagedreality.com :help:
  12. found this link but no pics :confused: 88 can you help linky
  13. i am about to trim the fenders on my 92 terrano 2.7td with 80mm body lift 50mm susp lift and 33x12.5x15 on 15x8 rims what i would like is a few pics of what people have done to their fenders.
  14. the bolt man at hyton parker said he has phoned around at least 14 general bolt shops and a few oddball shops but no luck. one shop had m10 threaded rod 2m at $170nz and it might be 8.8 ! but he told them where to go. a couple suggested rounding or cutting the bolt head off and rethreading to 1.25mm thread. could be done as the bolts i have are over lenght. as it turns out the man at hyton parker is a member of a few local 4x4 clubs and suggested that a few in the club had cut the floor pan to get at the captive nuts, removed them then just used a different bolt. is the captive nut just welded to a plate or else ? the lift will be about 80mm.
  15. i went to Hyton Parker and they said they will make some calls about the price i called someone in auckland and was quoted $100+ for the bolts my old man ordered the bolts from hyton parker he forget to mention the fine thread but still only $36 for 10 200mm high tensile bolts with nuts locknuts and washers. still waiting on the fine thread bolts for the captives
  16. Having trouble getting rear and middle bolts the ones that go into a captive nut. i can get the length ok but cant get the right thread on the bolt to fit the captive nut what bolt size and thread have people used ? my old bolts are: 8 x m10 2 x m12 rear new bolts are: 4 x m12 2 x m10 captive nut cant go up a size 4 x m12
