ben0326
Everything posted by ben0326
  1. What size strut spacer would I need to level out the stock suspension? I have a bull bar on the front and it makes the front sit much lower than it used to..
  2. I have the ones made by Nissan, I called a dealership and they had a few sitting around.. I would give that a try.
  3. If your not going to do serious off-roading I would just do new wheels and some A/T tires. Spend the rest of the $5000 on gas
  4. nice, is it just held on by the screws clamping down on it or is there something on the inside of it that makes it stay put
  5. Where did you get the antenna mount that mounts on the brushguard?
  6. The 8th one down is 31x10.5R15 for $144 per tire
  7. If your looking for just the rack look in a junkyard. I got a factory roof rack for 45 dollars from a junkyard.
  8. Would this same combination, 16x8 wheel with 4" BS and -12mm and 265/70/r16's work on a 1999.5 XE 4x4? edit- Actually the wheels I'm looking at are -11mm offset.. would the 1mm make that much of a difference?
  9. Im loving that pathfinder ronin. Where in PA are you from?
  10. This would replace the plastic skid plate.
  11. Would these level the front with the back on stock suspension? Or would it make the front higher than the back?
  12. I really like those seat covers. I might have to get a set for my birthday
  13. Thank you all for your input. Hopefully I'll get a chance to install these today! I'll let you know how it goes.
  14. Thanks for the information on the fuses. I have the harness that came with the lights and the wire that is supposed to be spliced into the high beams also connects to the switch and has two bullet connectors that connect to the actual harness. If I were to connect the harness to the switch but leave the high beam wire disconnected do you think this would still work? Sorry if I'm asking alot of common sense questions. I just don't want to fry anything and have to fix it. Thanks, Ben
  15. I got a set of IPF 968's for Christmas and had a quick question about wiring them. In the instructions it says to splice the wire into your high beam wires which makes the lights turn on only when your high beams are on. I would like to be able to operate the lights independently of the high beams or any lights at all. Which fuse should i splice the wire into to allow the lights to operate only when the key is turned to on? Or is there an easier way than splicing into a fuse? Thanks, Ben
  16. Hey thanks for the help! Hopefully I'll be able to get some tires that aren't bald before winter really starts, haha
  17. I'm guessing this is on the stock suspension? If so, how do they fit? Do they rub or anything like that?
