ben0326
About ben0326
  • Birthday 03/26/1991
    99.5 XE 4x4, SE Wheels, Roof Rack, 20% Tint, Cobra CB Radio, 255/70/R16 Michelin LTX AT2's, Westin Brushguard,
    XE
Contact Methods
  • Website URL
    http://
  • ICQ
    New London, PA
ben0326's Achievements
  1. What size strut spacer would I need to level out the stock suspension? I have a bull bar on the front and it makes the front sit much lower than it used to..
  2. I have the ones made by Nissan, I called a dealership and they had a few sitting around.. I would give that a try.
  3. If your not going to do serious off-roading I would just do new wheels and some A/T tires. Spend the rest of the $5000 on gas
  4. nice, is it just held on by the screws clamping down on it or is there something on the inside of it that makes it stay put
  5. Where did you get the antenna mount that mounts on the brushguard?
  6. The 8th one down is 31x10.5R15 for $144 per tire
  7. If your looking for just the rack look in a junkyard. I got a factory roof rack for 45 dollars from a junkyard.
  8. Would this same combination, 16x8 wheel with 4" BS and -12mm and 265/70/r16's work on a 1999.5 XE 4x4? edit- Actually the wheels I'm looking at are -11mm offset.. would the 1mm make that much of a difference?
  9. Im loving that pathfinder ronin. Where in PA are you from?
  10. This would replace the plastic skid plate.
  11. Would these level the front with the back on stock suspension? Or would it make the front higher than the back?
  12. I really like those seat covers. I might have to get a set for my birthday
  13. Thank you all for your input. Hopefully I'll get a chance to install these today! I'll let you know how it goes.
