MudFinder95
Everything posted by MudFinder95
  1. seems no one wants to buy a pathfinder, i couldnt sell the thing. so i bagged the sh!t out of it
  2. i have one yea but dont think its coming from that
  3. no water got inside. the beeping is coming from somewhere inside sounds like all around since its so loud. and i can unlock my drivers door from the outside and also the window only goes half down then un-aligns its self
  4. I drove my 95 LE through a pretty deep slew... got stuck a couple times and made it through a couple the water was up to the grille.. the alternator went so i bought a new one and now everything works fine except when im driving a loud beep comes on and off and sometimes stays on for a while.. my doors randomly lock and unlock by themselves and the starter randomly engages the odd time while its running? would the computer be fried? if so what year(s) of junkyard pathfinders should i use from if i cant find a 95.. and where even is the computer on my truck. Thanks
  5. sorry i couldnt get pics till after hockey.. also i decided to do it the faster way lol
  6. ok, i see them i think.. we'll see how it goes. thanks!
  7. i looked under the bumper and saw the black bar/mount thing going from the bumper to some where on the frame maybe. on the inside of the wheel well i have these rubber flaps. are the bolts behind the flaps by the frame?
  8. sounds hard im not seeing these 2 bolts...lol
  9. would i have to take the skid plate off to take off the bumper? because those bolts on there break forsure.
  10. Ok so i bought a pair of 3x5" 55watt halogen fog lights with the yellow lenses. and i want to mount them either on top of the front bumper on either side with has been done before a lot. OR cut out the plastic black bar beside the signal light and have them in there (they prob wont fit tho) so for the top how would i put on the nut to the underside of the bumper when mounting the light through the hole i drill in the top??? i dont want to take off the bumper because the bolts will all probably break. do you think i can take out the signal light bezel and reach my hand in there to do it? or how else would i do this.... Thanks! also i was bored so heres some random pics of the rig
  11. i want to hockey puck lift my 95 le.... maybe just 2 inches since i heard with a 3 inch you cant shift into 4lo and you need a rad mod or something. so should i go 2 or 3 inches? also what do i all need to buy, how many pucks needed, how long of bolts, anyone got a how-to on this....?
  12. going to in a bit.... i got hung up really bad in deep snow about a week ago if that helps.. but it didnt stop working until today so yeah
  13. my speedometer and odometer/trip also doesnt work as of this morning when leaving to school.. anybody know what could have gone wrong?? at least if i ever deside to sell, it will have less km's on it then it does lol
  14. that worked .. i had it on inside then set it to outside and now its good.
  15. its a 95 le, all the windows fog up so you cant see out of them exept for the windshield... No matter what setting i have it on (defrost high, low, etc.) Even if I get into the truck in my garage with no fog on the windows and leave to work with in 10 minutes i cant see out of the side windows... which means rolling them down to cross any roads or highways in the freezing weather of sk, canada.. I have nothing wet in my truck and have tried everything. Do i need to replace the heater core or what? because the windshield says good and clear and the heat still blows pretty warm. help!
  16. "need to know ASAP.., two relays, one switch?" So I'm running four 100w spot lights across my roof rack the box for the lights shows a 30amp relay for two lights. The guy at the store said I should run 2 relays and have one for each pair of lights. Does this mean that I can hook both relays up to one switch????? or do I need two switches for each set of lights which would be kinda annoying. Thanks in advance!
  17. I just balanced the 4 lights up there on top of the mounting base (which is why they stick up so high) what do you think? should I even put lights on my roof rack? would it look much better after the lift and mud tires are on you think???
  18. Thanks^ I just found pics of just an 3" BL with Pro Comp Mt 32x11.50 tires.. I think it looks pretty damn good!! can't wait till I get this now
  19. I just want to know the max tire height and width I can run with 3 inches of lift.... if people run 32x11.50's on 3" lifts then why would 33x12.50s rub on a 7" lift
  20. What tires are those? and your saying that these would fit on with a 3" BL and a little triming? http://store.summitracing.com/partdetail.a...mp;autoview=sku or these? (I like these alot better.. cheaper too!) http://store.summitracing.com/partdetail.a...mp;autoview=sku
