itsme1738
About itsme1738
  • Birthday 08/09/1966
    sas soa 513s,3 in bl,flat tops,high steer,knuckles turned,....bla,bla,bla
    colorado
itsme1738's Achievements
  1. 88 3.0 v6 30 degrees or lower it will not idle.....when its 30 or above,all is well
  2. thanks coung......found the air filter.....connot find the reed valve anywhere in the US stealership laughed at me!
  3. there is a filter in there (ordered 50 bux) and a reed valve.....cannot find the reed valve anywhere....truck has been running poorly on cold mornings
  4. i love my 88....sas soa,513s with 35s....its my dd every day now for 4 years
  5. i agree ryan,never cut corners......brakes and steering......took a little longer to save the cash but,it was well worth it.......flat top knuckles,high steer arms,1/4 wall dom,good tres,ect
  6. i did alot of research before i sased,this was 4 to 5 years ago.....i saw that the largest problem with a 3 in sl lift was steering.....there was fixes but,they were indeed tempoary.speending another grand,i could skip the sl and,go sas,sooooo around 2-2500 bux i skipped the sl and,with the help of ryan and,bill..got it done in a little over a weekend,its my dd for over 4 years now and,i never looked back....im no crawler for sure but its suits my purpose! 88 pathy,sas,soa,513s----DD hope this helps your cause ryan!
  7. ha! i was there when that happened.....i heleped him put in the spares in the rain, good times!!! and i seperated my front ds 4 trucks behind him i believe it was called the squeeze
  8. i have 513s/514s......its my dd 44 front 233a/b rear....a housing/b third....no real complants,speedo is 2 mph high
  9. i have the same hoop/shock setup on my rig....works great
  10. happened to me last year....when it snowed or rained(even parked overnight) it would run like crap...i tried everything...spent weeks....finally i grabbed the dist cap by accident and,it grabbed me right back,wow....turns out i had hair line cracks in the cap.....pull it off and use a bright light on the other side
  11. sooo ryan.....we can do the twin turbos on my rig then...
