Legalalien
Everything posted by Legalalien
  1. Sweeeeeeet Love the flex the SAS gives your truck (what was that thing that comes flyng out at the end? looks like a puley hope everything's OK
  2. How about making some sheet metal skirts to fit under the lights? that way you wont have to cut the grille. you obiously have the metal fabrication thing prety much mastered.
  3. Ain it F----- up when you get so involved tryng to find a solution to a problem that you forget to check the easy things? Thanks for reminding me dude I'll check for codes the next time it idles hi.
  4. Yup, I thought that hi temp was the problem so I back flushed the radiator and replased the termostat (the temp gauge was not working at the time due to a bad voltage reduser) I have repased the vr and the temp gauge stays at about 1/3 of the way up even when the truck is idiling hi.
  5. The A\C in my truck has not work since I have own it; it still has R12 in it but not enough presure to activate and I have no money to get the system resposibly evacuated for the R134a convertion. I'm guesing that you where thinking about a malfunctioning Idle up senuloid?
  6. Hi every one,My truck usualy idles about 900 RPM but some times (specialy when the weather is hot) it will idle at about 1300 RPM I have checked all the vacum hoses and replased the ones that didn't look to good hoping to eliminate the problem but it keeps doing the same thing. Any help will be greatly apreciated.
  7. Hey man, the sliders look great, what gauge pipe you used? I think this would make a great replasement for the factory nerf bars. the only thing I would change is to use u bolts instead of welds (not for fear of weakening the frame) but for the simple reason that if one gets damaged in the trail all it would take to remove it is a couple of wrenches, been welded, if they get bent enough to block the doors or rub a tire it would take a sawsall or a hacsaw (and allot of elbow grease) to get the damaged one off . no body intends to drop ther rig hard but it hapens anyway
  8. I have no idea how but the lights are now working (I guess I wigled the right thing ) Thanks to all of you for your sugestions
  9. LOL!! You bring the holy water and I'll buy the beer
  10. Tail lights are working perfrect and all the fuses check out ok, Im starting to think that I need a priest istead of a mechanic
  11. I know , what I don't know is why i'm getting power on both ore were the short might be. Any Ideas?
  12. Has anybody run into this problem? The dash board lights on my 91 dont work I have already cleaned the multyfunktion switchin the steering colum and replased the dimer control but they still don't work. I puled out the intrument cluster and checked voltage on the pink/blue wire and get 12 volts then I checked the pink/black wire wish should be ground and get 12 volts also. I have checked al the wires and bulbs and can't find any ovious problem I'm frustrated so if any of you have had or seen this problem please HELP!!!
  13. He guys, I just purchased headers for my pathy and wanted to ask everybody's opinion on header wrap; Does it realy help? what are the pro's and con's? what brand should I buy? I'll apresiate any and all coments or sugestions.
