ALL MODE doesn't have a neutral setting. Manual doesn't show flat towing a recommended option. It shows, for both Part time and ALL MODE that you have to have all four wheels off the ground when towing. If further goes on to warn you of Transfer case damage if you tow with only front wheels off the ground. You can't even reverse tow it or do a driveline disconnect. REMCO said that a driveline disconnect could be done. However, after putting the Pathfinder on a lift in 2WD and shifting into drive the front tires spin slightly. Therefore there still is some sort of clutches etc.... that remain connected and REMCO then said .... sorry, we can't help you.
I was just wondering if someone found a way around that. That would have been a $2000 solution if it would have worked.
I agree that towing on a trailer is the best option especially if that trailer has brakes on it. I have done that before behind the Motorhome. However, the wife for some reason didn't want to store or try to find a place for the trailer in the campgrounds. She is right it does take so shifting around in campsites etc... Or, It limits us to the pull through sites. I really think it's a storage thing for my wife.
So, I ended up with a '04 JEEP Wrangler that I paid 13K for to tow behind the Motorhome. It's easy to connect and disconnect but, I just thought someone might have figured out a way to flat tow our Pathfinders.
I think that's why you don't see any of our Pathy's behind Motorhomes going down the road.
Thx for the replies ..... AJ
