Nissyota88
About Nissyota88
- Birthday 11/18/1990
88se, tbar crank, zjsprings
16-21
1988
Contact Methods
Website URL
http://
ICQ
Gender
Redding,ca
Nissyota88's Achievements
NPORA Old-Timer (5/5)
it cost me like... 700.00 after all of that, if that much Also i work at mcyd's theres no benjamins here Also i have the blocks to level out the front, my rear springs are pretty much flat cause they are the 63"s and alot of people tha run the 63"s usually run blocks, good flex
Umm... then your pretty much using the same springs that are in the rear of your pathy right now.. i have some v8 ones if your lookin for some
I thought only children ran ifs? Its time to grow up, the fact that you pretty much have 2 completely stock paths. I mean im younger then you but... YOUR @!*%S WEAK
swear dude, its alot of unsprung weight also next fill up i will take some pictures and show you
ha... i bet you if we changed up i could pull you if we both put it in 4. Dude... i still still make them peel out, i get about 16 miles to the gallon but whatever .... can you run over cars? Oh and redfinder... stfu
Well i guess YOU would actually have to work on YOUR truck to know how that feels?
Your pretty much just putting on an aluminum shaft... whats the point? you need the nissan flange and the nissan yolk slip other then that your fskcked and if not more worse... go ahead and try to find someone that wants to weld the aluminum... for cheap
Blood sweat and tears into that? WTF did you do to it? put on different tires and a bugsheild... ohhhh shiiittt Hey atleast it died next to a first gen yota... aint that bad :tonguefinger:
TANNNER!!! dude i put dana 60's under my pathfinder and i also moved down to california sorry for never meeting you bro
I had to shim my axle and had no front shocks... i shimed my axle 6 deggrees and it doesnt do it anymore... :tonguefinger:
The reason he wrote off on the unsafe is because i hit a pothole right as he was pulling me over and its started to shimmy really bad
I got pulled over... worst thing is it started shimming cause i hit a pot hole as he was pulling me over. I need a steering stabilizer... Fix it tickets 1. no mudflaps 2. no left hand mirror 3. Unsafe vehicle needs steering shock
Heres a lil funfact for you about the fires... the president is in my town right now...
