racerdave
Everything posted by racerdave
  1. Sure do :-) I use to be one until I sold my business. Ok, and if I wanted to install a basket onto the rack, how would I go about doing that? I want to get something that has a wind deflector.
  2. How would one go about installing the rails that the racks clamp on to? My pathy didnt come with a rack, its just a bare roof, and I want to go to the junk yard and pull the rack off of another pathfinder. I take it I am going to need to pull my headliner, and drill holes?
  3. alright, it looks like I am going to be removing the front diff today then! Thanks for the info!
  4. I have a newer motor with less miles, I plan on taking my current motor out and putting in the newer one. I would like to know what the easiest way of doing this is. I am doing this by myself in my garage with a normal engine lift. I have tried to remove a few of the bellhousing bolts and its a huge pain in the ass, and im thinking about how I am going to have to line this all up on my own and put it all back together, I just dont think its going to happen. I have replaced engines before and I always pull the engine/tranny together as 1 unit and then set them on the ground, swap the tranny, and stick it back in. Just looking for advice.
  5. I need to know what is the best route.. Should I just pull the engine/tranny together, or pull the engine out and then the tranny? And when I install it, put the tranny on the engine before I put it back in? the link to the other thread is not getting much attention..
  6. Still doing mine... I need to know what is the best route.. Should I just pull the engine/tranny together, or pull the engine out and then the tranny? And when I install it, put the tranny on the engine before I put it back in?
  7. Is it easier to remove the tranny+engine, to replace the engine, or just the engine?
  8. Can anyone tell me why you have to drop the diff? So far, I have gotten all of my wiring disconnected, fluids drained, and radiator out. Today is accessory removal. AC, PS, starter and alternator.
  9. i was thinking about doing the same thing when I get my headers... Hmm.. Inspiration :-)
  10. Maybe... I have lots of tools, and friends to help.. I just pulled the pathy into the garage and drained all of the fluids, tomorrow is label and disconnect the wiring day. Having a cold and swapin a motor is no fun :-( Scarboy, how far have you gotten?
  11. thank you! I found a set of pace setters for $217 USD..
  12. You rock, looks like we are doing about the same thing.
  13. I am doing this as well, in my book it says to drop the front diff? I didnt understand why either?
  14. So I have my manuals out and I have been reading. I picked up a newer 95 VG30E (111k miles) to replace my 92 that has 330k miles on it. It is a 92 XE auto 4x4. I know lots of people on here have replaced the engine, I was just wondering if there is anything that makes this easier? Its straight forward in the book, but I find when I follow the book, there were always quicker/easier ways to do things... I have about a week to do the swap, its not my main source of transportation so thats not a big deal. Any helpful advice? The book tells me to drop the front diff, unbolt the tranny, and take the engine out. Well, not just that, but in that fashion. I am a little worried my engine hoist is not going to be able to pick it that high.... Can I take off the wheels and set the front on jack stands so the pathy sits a little lower? Also, can anyone direct me to a good place to buy a set of headers, I want to do that while the motor is out.
  15. Your best bet is to come out of the fender. Fiberglass is kind of iffy, as it can crack and leak. When designing it, you want the inside to be as smooth, and have the least ammount of bends possible. First off, you will want to remove the tube that goes from the air box, across the front of the truck towards the passenger side. Next u want to cap off that hole in the airbox where you removed the tube. I found Epoxy and a few small bolts work great (make sure u put the nuts on the outside, incease one comes loose. I tightend mine down, and coverd them in epoxy so they will never come off. A lot of people use PVC pipe (you have to keep in mind that UV rays destroy plastic after time) so get something that is going to hold up to the weather. That should get you brainstorming. Let me know if you have any more questions. Also, there are a lot of people on here that have made there own. So just keep asking.
  16. Not sure about how safe that is, but as for you putting in a Aftermarket cooler, good job!!! That is my next investment. Oh and here is a FSM for your rig in PDF format. 94 Pathfinder (yours is the same)
  17. racerdave
    VG30DE
    I am new to the Nissan World. Importing is how I started. I was a Subaru/Toyota/Honda guy. I bought my first S13 one year ago, been in Nissan love ever since :-)
  18. racerdave
    VG30DE
    You mean the 300z's that got the VG30*D*E ?
  19. racerdave
    VG30DE
    Thanks for the info! Like I said, it was free... It looks like im just going to make some $ off of it by selling it :-) Maybe pay for a set of headers and full exhaust for my pathy :-) I agree with a Low RPM tq curve for a off road'er.
  20. racerdave
    VG30DE
    I just picked up a free VG30DE. Im not sure what I want to do with it. It has low miles and nothing is wrong with it. The guy swapped it out for a VG30DETT, so.... Is it a simple swap into my pathfinder? I dont know anything about the VG and this is my first Pathfinder... Any help would be great :-) I like the numbers when u compare them to the VG30E... VG30DE Horsepower (SAE) 222 BHP @6,400 RPM Torque 198 FT-Lbs @4,800 RPM VG30E Horsepower (SAE) 165 @ 5200 Torque 174 FT-Lbs @4,000 RPM
  21. racerdave
    Code 21
    dude, u rock! This forum kicks @ss Thank you!
  22. Sounds to me like you have a stuck thermostat, and possibly air in the lines... When u crack the bleed screw, does any coolant come out?
  23. racerdave
    Code 21
    Well, I cant seem to find my OHM meeter, so I guess it will have to wait until tomorrow. :-\
  24. racerdave
    Code 21
    Yay, because a new distributor is like $$$ Thanks for the info, I am going out right now to check resistance and such. I will post the results tonight :-) thanks again.
