Fbanks
Everything posted by Fbanks
  1. I noticed that there were 2 Green/Red wires going to the relay, and I only checked the relay contact of one in my test above, so I took some more resistance readings on the relay itself with no power applied. I'm not sure what to expect or if this is really useful. But I noted the following: resistance across contacts 1-2 (as labeled on the relay)=75 ohms (contact 1 should be GND, while 2= blue/white wire) resistance across contacts 3-4= 0 ohms (contact 3 should be Blue/Black wire, while 4= Green/Red wire). Contact 4= top contact on the relay as shown in the manual All the other pairs showed an open circuit From the diagram in the manual, it looks like the readings on 3-4 could be normal, depending on voltage applied to the other contacts. Contacts 1-2 go across the windings of the relay. I'm not sure what that reading there should be, but I do note that the blue/white wire is involved here.
  2. I just thought of another quick test I could do. Since I noticed the issue only with the relay in place, I decided to unplug the relay, and check the ohmage between the blue/white and red/green wires on connector #118 coming into the relay. This showed an open. Since on the rear glass switch end, it also showed an open between these wires without the relay, I figured the issue must be the relay itself. When I ohmed the pins on the relay corresponding to those wires, I also saw an open, which surprised me since I was expecting to see the 265 ohms. Next, I got on the back of connector #118 with some paper clips, and read the ohmage between the blue/white and red/green wires. With the relay in place, I read the 265 ohms. When I unplugged the relay, I read an open. I'm not sure if this means my relay is bad (that would be my guess), or if somehow the relay is working properly but enabling some other path through which I'm reading the 265 ohms. Assuming it is the relay, any ideas on best place to get this?
  3. Well, I thought I had confirmed the rear glass switch was the problem. First, I disconnected the connector to the switch, and monitored pin 1 of connector #211. Before this was ~9v with the rear glass closed. When I disconnected the switch, I also got 9v, so I guess an open on the switch corresponds to hatch closed. Next, I shorted the connector going to the rear glass switch, and the voltage on pin 1 of #211 dropped to 0v. Next I decided to ohm the switch itself. On the connector coming from the switch, I read an open with the rear glass open. With the rear glass closed, I noticed the ohmage fluctuating, though it did eventually settle down to around ~2-3 ohms. I jiggled the connector a little, and noticed large fluctuations. I thought the wiring was probably bad, but luckily I have some long springy leads where I was able to reach directly on the contacts of the switch. I noticed these same fluctuations when I manually depressed the switch button, so I thought for sure the switch was my problem. I sprayed some electronic cleaner on the switch and got it to where it was reading 0.8 ohms with the button out, and an open when the button was depressed. I felt sure this would solve my problem. I decided to test with the rear glass switch disconnected. I started with the connector going to the switch shorted, to emulate the rear glass open. Sure enough, when I did this, the rear wiper would not operate, regardless of the dash switch position. Next, I disconnected the jumper on the rear glass switch connector, thinking I should have normal wiper operation. Unfortunately, the rear wiper would not shut off, as before. I was puzzled, so I went back to the rear glass switch leads. I noticed that with the rear glass closed, I was not seeing a full open on the switch any longer, but instead something like 265 ohms. I thought maybe the switch was bad, but when I disconnected the switch from the wiring harness, I noticed it now showed a solid open again. I then ohmed the other side of connector #160 (coming from the wiring harness) and I also read ~265 ohms between the wires going to the switch. From this, it appears that there is some issue between the blue/white wire and green/red wire going to the switch. I disconnected the dash switch just to see if that made any difference, and it did not. I then disconnected the rear wiper relay at connector #118, and I then measured an open on the rear glass switch with the glass closed. Could the rear wiper relay be bad, and this causing the issue? I was hoping I might have another elsewhere in the truck I could swap it out with to test, but I did not see one at a glance. I'll try to see if the manual shows a test procedure for this relay.
  4. Thanks a lot for the suggestions, I'll try to do a little more tomorrow when the weather is cooperating better. You mentioned a fuse blowing and another circuit, and it made me think of something else that I should have mentioned. I remember after replacing the fusible link, turning the ignition on to test things. Everything seemed normal, but I noticed that my power locks were not working. I pulled the fuse (10a, as I recall), and it was burned. I replaced that fuse, and the locks returned to operating normally. I didn't think about it again until your mention above of a blown fuse and another circuit, and it rung a bell. For sure, the fusible link did look quite old and there was noticeable corrosion around the terminals. From the looks of it, I do believe this had been replaced one time before, as it was clearly not the stock connectorized fusible link that is shown by Nissan (Nissan part #24021-V5112). Maybe the replacement fusible link was undersized? I'm not sure what gauge that fusible link should be, but I think I read somewhere it was 16 gauge, but I wasn't sure this was right. I used 14 gauge based on the size of the terminals/spade connectors, but that was just a guess. I actually would have guessed 12 gauge, but I was afraid to go with too large of a fusible link and defeat the purpose. This is the fusible link that powers the instrument panel (i know just because nothing on the instrument panel was working), and based on the blown fuse, I guess the power locks as well. I don't know if this same fusible link ties into the rear wipers, but I guess that might make sense with the switch being on the dash. It looks like there's a connector right there by the switch for the glass hatch, so I should be able to disconnect the switch easily enough, and open or short the connector and check the voltage on the white/blue wire (pin 1 of connector 211) easily enough. If that solves the problem, then I'll know it's the switch. I'll let you know what I find. Many thanks again for all your help! I'd be like a blind squirrel here without your advice.
  5. I did another check at the motor itself- with the wiper running, I checked the voltage from ground (black wire) to the blue/black wire- this read a pretty constant ~11.9v, and did not seem to fluctuate with the arm position. I also read the voltage on the solid blue wire at the motor, and this voltage definitely fluctuated, mostly being at 0, but spiking each time the wiper arm went toward the stop/return position. I only have a multimeter and no o-scope, so I can't tell exactly how high the voltage spike was, but it looked to be north of 10v, so I would say it probably reached ~12v and my meter just wasn't able to capture it. I checked this same voltage on the blue/black wire at the relay, and it also read a pretty constant ~12v. While I was at the relay, I also checked all the pins coming in to make sure there were no shorts to ground at the relay, and I found none (except ground itself, of course). I'm thinking this means my motor is good, but please correct me if I'm wrong. The problem seems to point to either the amplifier, or potentially a wiring fault somewhere. I suppose it's possible the same fault that caused my fusible link to burn could also have damaged the amplifier at the same time. I'm guessing that amplifier is in the side panel on the driver's side. Do those plastic panels just pop out, or is there some trick to it? P.S.- I'm not sure my Pathfinder matches exactly your diagram, as except for the one unused pin it shows on the motor connector, I have wires connected to all pins on the connector, while the diagram from your manual seems to show 2 unused pins on the left side of the connector in the diagram. i'm not sure that's important, or if those wires are really used, or just extra unused wires.
  6. I'm looking at the diagram a little more, and what I wrote above, and something else is bothering me as well. I read 12V on pin 9 (black/blue wire) of connector #211, but I note that the switch will short pin 8 (ground) to pin 9 in the on/interval positions. This seems like it would be problematic too. The black/blue wire also originates from the rear wiper amplifier, if I'm not mistaken. I'm going to check the documentation you gave me to see if it gives some explanation of the pinout, and what exactly each of the wires control (inputs vs outputs, function, etc.)
  7. Update- using the wiring diagram you gave me, I checked the switch, and it operates as it should with the switch in all the various positions. So I'm confident the issue is not in the switch. While I had the switch out, I went ahead and checked some voltages on the connector coming into the switch (conn. # 211). From the diagram, i could see pin 8 (black wire)= ground, so I used that for my ground (please tell me if I'm mistaken here). Pin 9 (blue/black wire) read 12V, and the rest were all close to 0, except pin 1 (white/blue wire), which read 9.1V. Something seemed obviously not right there, unless that line just floats when not connected. Following the diagram back, I see the white/blue goes through a few connectors, but eventually comes from the rear wiper amplifier at connector #48. I was unable to locate this amplifier, so I can't check the output there, but my guess at this point is that this amplifier may be the problem, since the white/blue wire seems to originate from there. If you can tell me where this is physically located, I can try to verify further. I did find the rear wiper relay, and checked voltages there. Using the black wire on connector #118 as ground, all voltages read 0 except the 2 green/red wires, which both read 12v. If I disconnected the relay and read the voltages again at the dash switch connector #211, then I got 0V everywhere (except pin 6, if I recall correctly, which gave some small voltage reading of 0.1-0.2V). I did confirm the mechanical switch I was looking at before was the back hatch disable switch, that apparently only gets pushed in when the wiper arm goes all the way down to the rest bar. Am I on the right track here, or do you have some better suggestions for me to try?
  8. Thank you for your help! I've printed out the relevant pages, and will take a look at the signals coming to the motor. So the switch I saw was likely then the hatch switch that you're mentioning. I'll try to remember to verify that. If that's the case, then I expect it only gets activated when the wiper fully goes to the rest position (resting on the rest bar), which only happens (or should) when it is shut off. Then there must be another switch/contact somewhere then that notifies the motor when the wiper gets to the stop/return position (close to the edge of the window, as opposed to the rest bar). You mentioned the "wipers in the motor that keep it going back to its home position". I'm not sure exactly what you're referring to there, so I'm not sure I did check that out. I'll do some more investigations and report back what I find. Thx again!
  9. I removed the rear panel, and was going to upload a video (17 seconds) of the rear wiper at work, showing the motor, switch, and mechanics at work. However, it would not let me upload a video, so I'll try to describe it. I did see a single mechanical switch that appears it should be pushed in when the wiper arm returns toward the rest position. However, the mechanical arm that rotates around never actually touches the switch. I thought for sure this was the problem, but even if I manually push the button on the switch and hold it in for a couple of revolutions, the wiper never stops. I did try it in all positions of the rear wiper dash switch, just to be safe. I'm not sure why whis would be, unless I'm unlucky enough to also have the dash switch never actually telling the motor to shut off, or if there's a short/open somewhere. In any event, it seems I have a problem with the switch by the motor not being activated. Does anyone know how to adjust the mechanical arm so that it would activate that switch? If you could see the video, you would see that the wiper arm doesn't actually go all the way down to the rest on the returns. That might relate to why the switch is not being pushed in. Actually, as I'm looking at the video closely, I can see there is some adjustment possible for the switch itself. I'm not sure there's enough play in the mounting to allow the switch to be activated, but I'll check that out more closely tomorrow. I'm also not sure why the switch would have moved/need adjusting? Is there also an adjustment that can be made on the rotating arm? That seems more likely in need of adjustment, since it's in constant motion when the wiper is on. Assuming I can get this sorted out, then it still seems I have a problem, since the wiper doesn't cut off when I manually depress the switch by the motor. If I had a pinout of the connector that plugs into the motor, and an explanation of how it works, I could at least eliminate any issues upstream of the rear wiper and motor. A pinout of the switch itself would also be nice.
  10. Thank you for the offer! Please see this thread: Wiring diagrams pertaining to the rear wiper (switch and motor side) would be very helpful. And of course, any specific advice you have on this problem as well.
  11. Hi everyone, I have a 1987 Pathfinder (SE) and the rear wiper will not shut off unless I remove the fuse. I had assumed perhaps the switch on the dash was bad, as the wiper goes the same speed whether it's in the intermittent, off, or on position. It will actually release wiper fluid if I push it all the way to the right, but other than that, the wiper does not react to the switch position. I did access the rear wiper switch on the dash, and pulled it out. Wiper does not activate with switch removed. I took the switch apart and looked it over, and it looks pretty simple. Springs for the contacts looked good, and the contacts on both the slider and the plug end looked clean, so no obvious issues. I don't have the pinout to test this, so if anybody has that, and/or the pinout on the rear wiper motor side, that would be awesome. My guess now is something to do with the wiper motor. I'll plan on taking the back hatch cover off to take a look. If anyone can direct me to a pinout for the connector there, I'll check out the different switch positions to make sure all looks good on that side. Then if that checks out, I guess it's down to the motor itself. I understand there is a contact in the wiper motor that tells it when it reaches the stop/rest position. Perhaps something is wrong there. I do notice that my wiper never goes all the way down to the rest bar, but I was thinking this was normal during operation, since the wiper blade is beyond the window pane when it rests on the rest bar. I guess the way it's supposed to work is that once the switch goes to the off position, then the contact should send it farther down past the window to the rest position, once it's triggered (and the switch is in the off position). Perhaps the contact is bad? If anyone can confirm whether the wiper should go fully to the rest bar even during operation, or only once the switch is in the off position, that would help. And if there's a procedure to adjust the wiper arm or motor contact, that would be very much appreciated! I should mention that this problem seems to have occurred at the same time that I had a fusible link burn up. The truck was operating fine (according to my brother who was using it), when power to the instrument cluster was lost. The truck continued to run fine, and he continued home with the truck, and let me know what had happened. I turned the ignition on to verify, and the rear wiper immediately came on, and I smelled a burning smell. My brother said the rear wiper was not running for him, though it's possible he just never noticed. I pulled the fuse to the rear wiper, but continued to smell the burning smell. When I looked under the hood, I could see a fusible link that had pretty much burned through. I've since replaced that, and the instrument cluster seems to be operating fine. I no longer smell the burning, and the fusible link does not seem to be getting hot, although I"ve not operated the truck for very long since. The rear wiper continues to run continuously, unless I pull the fuse. I cannot be sure that the fusible link issue is related, but it seems coincidental, so I wanted to put that information out there. Thanks for any and all help!
