enochian
    99 Pathfinder Automatic 4WD
    Do Not Go Off-Road
    OH
enochian's Achievements
  1. Where do you buy that little plate the self-adjuster hooks onto? I'm talking about in the rear drum brakes.
  2. I'll check the brake lines. What about bad wheel cylinders?
  3. After I got the front CV axles done, I have an ABS light. Shop doesn't want to fix it. But now I have a soft brake pedal. Related or coincidence?
  4. These are the CV axles I bought: https://www.rockauto.com/en/parts/cardone,666185,cv+axle,2288
  5. Hey can someone explain how the ABS sensors become disconnected? I'm having the exact same situation as the original poster. Everything looks good when I look behind the wheels.
  6. Well it was doing that lurching thing even before I did the front CVs. Lurches like the brake releasing. Also the ABS wires and sensors look fine from the outside.
  7. ABS light on after front CV axles replaced. Car still lurches forward sometimes. Any idea whats going with both of these?
  8. Is this it? How do I remove it? https://i.ibb.co/wNPh5JX/IMG-20200915-094010131.jpg
