skywhr
Everything posted by skywhr
4x4parts.com sells the shrockworks bumper the iron bull bumper appears to be for the titan which wont fit the frontier or the pathfinder another option http://www.kenmtn.com/html/wincher.asp http://www.kenmtnac.com/WiFron2005.html
Lift For 05 Le + Accessories ***updated
skywhr replied to skywhr's topic in 2005-2012 R51 Pathfinders
Which AC lift did you install. Can you link it? -
So I got my Shrockworks rock sliders on finally 4x4parts.com finally has a 2" suspension lift and I cant believe that I am actually considering getting the 5" calmini lift -
just installed skid plates , they went on easy
skywhr replied to jerry6's topic in 2005-2012 R51 Pathfinders
how much was shipping on these? -
Anyone ever see 1 of these in person? http://smartbar.net.au/arbitrage/pages/241
I had planned on getting 285/70R17 Bridgestone Dueler A/T Revo on stock wheels, but I am not sure yet -
2" spacer all around installed!!!! need new shoes any recommendations? misc after lift pics http://www.thenissanpath.com/posting.php?mode=reply&t=1524 -
OME Suspension lift for 2005+ Pathfinder
skywhr replied to Earljam's topic in 2005-2012 R51 Pathfinders
https://www.4x4parts.com/catalog/product_in...roducts_id=5496 -
Wheels - Offsets + Lug patterns?
skywhr replied to VillageIdiot's topic in 2005-2012 R51 Pathfinders
Offset: 30mm Backspacing: 5.74" Bolt Pattern: 6-114 http://www.4wheelparts.com/partLists.aspx?...9&w=1415-14 -
Rancho makes shocks for the r51, go to products>nissan>other applications
available here https://www.4x4parts.com/catalog/index.php?...415_339_606_605
Rasta 4x4 now offers full skids for R51's
skywhr replied to 88pathoffroad's topic in 2005-2012 R51 Pathfinders
do you have to request a quote to get the prices? -
I believe when I priced the shrockworks skids if you got all of them w/ powder coat + shipping it was approx $1000 In order for you to price them for yourself you go onto the shrockworks site and put the xtera skids in your cart and then put in your zip to see full cost. I spoke with a guy there and he said to the the above to get your cost and then call in your order and make sure you tell them they are for the r51 so they can make the appropriate changes. I have a few ideas Im going to explore in the near future
Just checked availability....all but the transmission cover are oos
From Courtesy Nissan: The engine cover skid plate is part number 50842-ESPFR The transfer case cover skid plate is part number 50884-TSP00 And the fuel tank skid plate is part number 50890-EA500 Don't forget to get 13 skid plate bolts, part number 01121-06561
Rancho is looking for 05-06 Pathfinders for product development http://www.gorancho.com/vehicles_needed.php Im on the other side of the us so Im out, I would gladly let them have my pathy
spoke with a guy @ prg today after receiving the spacers. asked him a few questions and got some really interesting answers He said to gain lift in the back swap out the spring with the armada spring and that would give you 3 1/2" lift but that they currently didnt have a shock for the rear that would fit it and when doing this you would really need to upgrade the shock. For the front he said everything they offer for the frontier in the front would work on the pathfinder so I am eyeing the PRG Radflo 2.0 coilovers and PRG upper control arms for the front within the next 6 months and then I will have to figure out what to do about the shock in the rear.
anyone up for the task of taking the measurements? then we can all do a group order? i am not detail oriented enough to do it accurately unfortunately
This is the info needed for him to fab a body lift. I've got an XYZ vehicle, do you make a body lift kit for it? * If it is not listed here, then 4Crawler Offroad doesn't have a design available for that application. But, everything listed on this page, outside the early Toyota 4Runner kits, has been designed with the help of people just like you that asked this very question. * If you are willing to do the small amount of research needed to help 4Crawler Offroad design and build the kit, chances are the answer will be YES! o First, verify that the vehicle uses a body-on-frame construction. + Many modern vehicles use a uni-body or uni-frame construction where the body and frame end up being one piece. + If there are no body mounts, bushings or bolts visible underneath, then chances are the body can't be raised off the frame with a body lift. o Then, you need to know how many body mounts the vehicle has, a rough idea of what size they are (i.e. 2" dia, 2.5" dia., etc.) what size the mounting hardware is (diameter and working length for each mount - sometimes there is unused thread on bolts). o If items need relocating like bumpers, radiators, etc., we'll need to know details on how they are mounted to the frame. You'll need to supply information on the size of the mounting bolts and the spacing of the holes (e.g. 12mm bolts, 60mm on center - then a bracket can be designed based upon this data). o Getting this data won't be all that hard, get under your rig and count the body mount locations. Find where all the bolts are, you should be able to loosen and remove one at a time, pull it out, measure it and put it back. + Get dimensions, take pictures, and send them to 4Crawler Offroad. + Bolt lengths are measured from the bottom of the head to the end of the shaft, DO NOT include the height of the head in the length. Also, some vehicles have, for example a 5" long bolt, but with 1" of thread exposed when installed, so, this should be noted, e.g. 'Bolt 5" long w/ 1" exposed thread'. + Bolt diameters are measured at the shaft, its not the size of wrench that fits on the head. + If a bolt goes into a captive nut inside the body, then the thread pitch (i.e. SAE, this will be Threads Per Inch, and if metric it'll be in mm/thread) will need to be measured. + Don't assume all bolts are the same diameter or length. They are usually the same side to side, but can be vastly different sizes in different locations. And don't just measure down from the underside of the floor or guess, you really need to pull the bolt out, measure the length and best if you can send a photo of all the bolts side by side with a ruler for scale. If should be no problem to remove a body mount bolt, no vehicle support is needed, gravity will keep the body in place, just make sure you put them back before driving it! o So you provide 4Crawler Offroad with the specifications, you will get a "custom" kit with no extra charge for the custom design work. + 4Crawler Offroad will hope to make up the design cost in additional sales of kits for that application. o This was recently done for the Kia Sportage body lift kit. Within 2 weeks of the initial contact, a kit had been designed, manufactured, and installed on the owners truck. A similar turnaround was seen fior the 3rd and 4th generation Toyota 4Runners. o A 3" body lift is about the tallest that is safe and reasonable. + If planning a body lift over 3", please consider cutting the brackets off the frame and raise them up the desired amount and weld them on with added bracing. The life you save may be your own! o XYZ is not any specific vehicle, replace XYZ with Dodge, Jeep, Ford, or whatever vehicle you have and are interested in having a body lift kit designed for. o Cost will depend on the quantity and size of the blocks and hardware desired, here is some typical prices of some of the items: + 2" OD UHMW blocks are $5.00/ea. for 1" tall and add $1.50/inch (or any fraction thereof) over 1" tall. + 2-1/2" OD UHMW blocks run $6.00/ea. for 1" tall and add $2.00/inch (or fraction thereof) over 1" tall. + 3" OD UHMW blocks run $8.00/ea. for 1" tall and add $3.00/inch (or fraction thereof) over 1" tall. + 3-1/2" OD UHMW blocks run $10.00/ea. for 1" tall and add $4.00/inch (or fraction thereof) over 1" tall. + Longer bolts can run from $2.50/ea. to $5.00/ea. depending on diameter, length and grade.
This guy says he can make custom body lifts for most vehicles; http://www.4crawler.com/4x4/ForSale/BodyLiftKit.shtml I have an email into him, waiting for a response more to come
Stock tires and wheels actually its completely stock cept for the k&n drop in filter
I will post pictures after I do the install and get it aligned. Probably wont be putting new tires on it for a bit $$$$ I need to, stock tires are awful Ive never had problems with hydro plaining before I got this vehicle
When I ordered it they site said it would take from 1-4 weeks. I got an email today sayin it has shipped and will be here by May 2nd. Cant wait
ordered today need new wheels now 285 75 17's here i come
PRG 2" front and rear $269 http://www.prgproducts.com/shop/category/p...der_suspension/
