MrFister1975
About MrFister1975
- Birthday 03/04/1975
1995 Pathfinder SE-V6 Automatic Transmission Leather Interior Pop Out Sunroof Rear Tire Carrier Front Bull Bar w/ Factory Mounted Fog/Driving Lights Adjustable Suspension (No Longer Connected) Factory Alarm Heated Front Seats Pop Open Rear Glass Switch Stock Lego Wheels 31x10.50 All-Season Radials Stock Lego Spare Wheel (Found at Junkyard) 29x10.50 BF Goodrich A/T Factory Mounted Roof Rack 1995 Pathfinder XE-V6 Completely Bare Bones Stock Used for parts now
40-45
1995
Gender
Country
MrFister1975's Achievements
After owning a 89 4Runner with a soft top swap, quite is better. Now ask yourself this, other than cool factor, what will be the ups and downs of doing this? I would also ask yourself how often it will need replacing? What will be the impact of weather (ie rain, snow, moister) damaging the ENTIRE interior of your truck? If you think the ups out way the downs then go for it. Mr. Fister 95 SE-V6
If you are putting a 2" lift on your ride, you should be able to put 32" under it with no problems. You might even be able to go to 33"x10.50 which overall is a more common tire and save you some money. I personally want to level out my 95 by raising the front or lowering the rear. I have the same set as you do currently 31x10.50r with the Lego wheels.
Rear glass lift support questions
MrFister1975 replied to dblockinc1's topic in 90-95 WD21 Pathfinders
I just replaced all 4 shocks on my 95. 2 on the glass & 2 on the gate. You need to take a small Crestent Wrench and remove the bolt with the ball on it. It is all one piece -
Suggeations for Plugs & Wires
MrFister1975 replied to MrFister1975's topic in 90-95 WD21 Pathfinders
I just bought it in December and have no idea what has been done to her. It is running great honestly, especially compared to my XE that is sitting in the backyard as my as needed parts truck. I will say the difference in the base model 5-Speed XE to the fully loaded Automatic SE is night and day. -
Ok so NGK Wires, NGK V-Power plugs, Duralast cap and rotor. I just replaced all 3 belts with Gates XL Belts. I also had to install a new cooling fan due to the shroud being cracked. I also change my oil and filter every 3000 to 5000 miles with Castrol GTX 10W-30. I live down in Florida and 10w-30 is S.O.P. down here. Now with all that said and done, what else should I check and/or replace as part of a solid tune-up. Thanks for all the advice, you guys are saving me a ton of time as well as money. Mr. F -
Hello Folks, I am about to do a full Tune-Up on my 95 SE, and was looking for some Plugs g Wires suggestions. I have been eyeing the NGK Iridium IX Plugs, and the NGK OEM replacement wire set, ignition coil, & O2 sensor. I was wondering if anyone has this setup or any other suggestions? Thanks in Advance, Mr. F
My factor fog light switch is on the driver's side next to the E-Brake. I have a 95 SE with 6 switches located next to the E-Brake. 2 Bottom: Heated Front Seats 2 Middle: - Drivers Side - Fog Lights - Passenger Side - Suspension Adjustments 2 Top: - Drivers Side - Rear Glass Pop Switch - Passenger Side - Factory Car Alarm Hope this Helps.
I found an App called Car-Part.com that uses your location and displays ads from mostly salvage yards for all sorts of parts around you. I would look here. Not sure if you are a iPhone or Android phone user, so sending you a link from the Google Play Store. Car-Part.com App: https://play.google.com/store/apps/details?id=com.carpart.classic
New To NPORA Board & Have A/C Question
After digging a little bit, it seems from 93 to 95 all Pathfinder's had R134a A/C http://www.techchoiceparts.com/refrigerant-and-oil-capacities/nissan -
Thank you for your help Sir... -
Yes Sir, my truck is a 95. Is there anyway I can make sure myself by looking? I have the 90 to 95 Pathfinder, and I have my old 95 XE-V6 base model that I retired to the backyard to part out. -
Good Afternoon, I am a noob to your form, but glad I found it. I am looking for an A/C Conversion Kit to go from R12 or R22 to R134a. I tried the local AutoZone and they no longer have them in their systems. Can anyone suggest a good conversion kit and also a good diagram or YouTube video on how to do it. My A/C has been spotty here the last couple days, and now it is just blowing hot air. I live in Florida, and with summer right around the corner, I need my A/C. Thanks for any and all help in advance. Mr. Fister
