Baker95pathy
Everything posted by Baker95pathy
The switch is off and when I turn it on it runs higher rpms
Yes overdrive is working. It shifts through every gear fine .
New timinng belt but wont start
Baker95pathy replied to Baker95pathy's topic in 90-95 WD21 Pathfinders
I think I have a bent valve or more than 1. I'm ganna check compression to be sure but probably ganna get knew heads. But should I rebuild the ones I have or get new or get some off of a wrecked junker. -
Ok well I turned the engine about 10 to 12 times by hand and my marks on the belt and the gears are different every time. Shouldn't they line back up after a few rounds. -
Yes -
Ok all timing is correct but it still won't start. It will almost start but then it just starts turning slow again. Still has a little back fire but no flame out the breather anymore. I'm stuck. -
Ok I counted the teeth on the belt and I was 1 off on top fixed that. Now I'm ganna check the ignition timing again to see where I'm at. -
Should the cams be hard to turn. My crank is a little tough to turn but that's normal what about the cams. -
Ok I do not have a way to test compression but when I try to start it with the breather off it occasionally blows a flame out the breather. -
I just bought a 95 nissan pathfinder. It has set for 4 months. The guy said he the timing belt broke he replaced it but it would not start. I checked and the timing was not set correctly. I set it correctly but it still won't start. The engine seems to be turning slow to me. I'm getting fire and I'm pretty sure I'm getting fuel because when I pulled out a plug it smelled like gas. Can someone please help me. -
New timing belt but won't start
Ok my pathfinder runs 3000 to 3500 rpm at 45 to 50 mph. I know that's to high but it seems to be shifting properly. Any ideas?
Jgc not Ngoc
And are there some shocks. Ngoc or others that will fit for the back
Ifs huh? Will it be wobly without the rear sway bar? I will be getting new uca in the near future but for now this is all I can do.
I am fixing to lift my pathfinder with jeep grand Cherokee coil springs and a reindex of my t bars.do I have to change shocks or do anything with the sway bar links?
Lifting and modifying my $400 pathfinder
If I do the deep coil springs and reindex my t bars do I need to get different shocks and do I need to do anything with the sway bar links.
Rear Spring Options For Lifting Your WD21 Pathy
Baker95pathy replied to 88pathoffroad's topic in How-To's
Ok I'm trying to lift my pathfinder and I'm ganna use the jeep springs and reindex my t bars do I need to get different shocks and do I need to do anything with the sway bar links.
