Zkingcyrus
Everything posted by Zkingcyrus
  1. I'm having some issues with the door locks and the power windows, I can't find the circuit breaker on my 1995. Any help?
  2. It could also be a bad fan clutch. Mine spins all the time and makes a ton of noise. Cruising at a steady speed it will fade in and out in volume but always makes some noise. I thought I was the timing belt at first but it's too inconsistent.
  3. Well, I tried "everything". I pulled up the gsm and followed the diagram searching for the "circuit breaker" next to the fuse panel. Finally gave up and decided to swap a few grounding screws before I put it back together and that ended up solving my problem. Good luck to everyone else with window issues!
  4. I tested the 5 fusible wires that come off of the battery (lead to negative terminal). All were showing 12v. When I tested the other sides of the circuit (from battery terminal); 1/5 show 12v with the key off, 4/5 show 12v with the key on. The door lock button is also not working. The windows were working momentarily today but everything died again after I put 2 down.
  5. Im not getting any power to the switch. Windows stuck up, automatic locks not working either. It happenend a few times and completely quit today. I pulled the amplifier but capacitors tested fine and toggle were clean/unburned. I can't figure out which relay/fusible linke feeds power to windows, any guidance would be appreciated.
  6. After further review it seems: I have power to both gauges. Continuity through both circuits. 2 ohms through the temp circuit when warm and 1 ohm through gas, likely almost empty. My gas gauge may be working, need to fill her up and see. The needle moves a tiny bit when power comes on, barely noticeable unless I'm staring at it like today. Hoping I just need a new temp gauge.
  7. After further review it seems: I have power to both gauges. Continuity through both circuits. 2 ohms through the temp circuit when warm and 1 ohm through gas, likely almost empty. My gas gauge may be working, need to fill her up and see. The needle moves a tiny bit when power comes on, barely noticeable unless I'm staring at it like today. Hoping I just need a new temp gauge.
  8. Neither gauge is working in my 95. I have read the fix, but the panel on the 95 does not have the voltage regulator in the top corner, Ii am hoping someone can point me in the right direction to get them working again.
