Petercan1020
Petercan1020 last won the day on February 4 2017
Petercan1020 had the most liked content!
    2002 Nissan Pathfinder LE 4 wheel drive 177708 miles today is March 2nd 2016 afford this car with 155000 miles in September 4th 2015 the only thing I've done so far is put au joint in the front and tires
    Choose
    Ny
1,827 profile views
Petercan1020's Achievements
NPORA Regular (2/5)
5
  1. This is what i mean i get both answers i know on 2011 its the bottom i need a definite answer and cant find it ty though
  2. I just needed to know what side the inner rubber ring on the caliper pins there's one on each side one ring for every two pins I was reading different things some people saying bottom some people saying top I was just looking to see which was correct and couldn't find a straight answer I wasn't talking about the two outer boots that you can see just the one that goes on the slide pin inside the caliper 1 per side thank you
  3. Yes im speaking about the boot that slides inside the caliper there's one on each side not the two boots on the outside that you can see
  4. I have an 02 Nissan Pathfinder and I'm putting on new brakes and decided to change the caliper pins on both sides cuz it didn't look like any of them matched does anybody know on this year 2002 Pathfinder if the rubber boot is in the top slide position of the caliper or the bottom position of the caliper I can't find a straight answer
  5. I was losing like a Court every 600 miles
  6. I had the same thing I changed out the oil cooler two seals and it went away
  7. So do i attach any wires or connect any wires to the O2 sensors and then run the ground 2 spot on the car I read that the O2 sensors will start giving codes because the grounds seem to rot out or just get a bad connection, are we talking about the same thing
  8. I put them on the computer and they seem to be running normal could an exhaust leak cause this behind the cat on the passenger or a hole in my muffler?
  9. A video stating that you can ground or fix the ground with the 02 census ground to the motor and run a separate ground wire to the battery does anybody know where the ground location would be on an 02 Pathfinder going to the motor intake manifold all I see are the blue plugs for the O2 sensors but I can't find the ground to the motor I saw a video on YouTube doing in on an Xterra but the motor looks different
  10. And does anyone know where the ground location is for the O2 sensor I hear there's a quick fix for it but I don't know how to wire it up or where to install the wire except for the battery
  11. cam sensors and crank sensors have to do with it there are two cam sensors and one crank sensor I got some cheap off of Amazon I think I paid less than 75 dollars for all 3 of them original Nissan parts too. Is check engine light is coming on?
  12. check they are not in wrong but they where very tight putting them in.
