Meatsac last won the day on November 6 2016
Meatsac had the most liked content!
About Meatsac
- Birthday 02/21/1990
Two door '91 z24 standard as far as I know.
Other/Unknown
1991
Gender
Queenstown
Country
New Zealand
Interests
Skateboards, kayaks, MTB and 4wd
Meatsac's Achievements
NPORA Regular (2/5)
17
Ok so stil working on this and not getting anywhere really. at least i have a multimeter and a suspected culprit. Here is a picture of the relay that the above nissan 720 article is relating to (BTW if anyone has a FSM for a non injected Z24 i would really appreciate it). I measured the voltage in at all the ignition positions and came back with this Colour Running (v) On (v) Accessory (v) Off (v) White -0.02 0 0 0 White Red 15.4 12.6 12.6 12.6 Yellow 15.4 12.6 12.6 12.6 White Black 0.34 <10* 12.6 12.6 White Blue 0.38 <10* 12.6 12.6 Black 15.4 12.6 12.6 12.6 * these numbers were continually running down, should have checked them before i started it but i didnt. I checked continuity from the white wire to the ignition switch at it was ok. below is the diagram, presumably of the same relay but in a 720 as that is what the article referred to. My electronics are all working fine except for 2 things: 1)Most of the time the key won't shut off the engine. I have to bring it to bite point, turn off the key and then hit a killswitch (that i have no idea how it functions) 2)Battery light is always on in while the engine is running. If anyone can help point me in the right direction towards fixing either of these i will be eternally grateful. Thanks Terranovation for setting me on the right path.
Thanks! From, the future.
Sweet, so new zealand is the land of the d21 then. There's at least three others parked within 200m of my house
Out of intrerest, how many pathfinders do you see about? Are they rare near you? Personally I've seen probably 10 today after 4hrs of driving, half of which was well away from traffic. They're all terrano's here but i've seen a few actual pathfinders too. Usually one comes for sale every day or two.
so you take the battery out and bring it into your house and then stick an electric blanket around it? that's tickled me that has
So I did it and bought some new hubs and, surprise surprise, it was them all down to them. Really appreciate the help of the community, feel like i understand differentials a bit more now. I realise this question crops up a fair bit, having found a couple of other similar threads after posting, but if we all went around only asking original questions then the world would be pretty quiet right? Now all I have to do is get the fuel pump to shut off with the ignition and she'll be ruinning as good as new. Thanks again Pathfamily
Can I force the hubs to stay locked or something? They both looked the same when I opened them up, but they could easily have both been screwed.
That's what I've been hoping. I just thought that CV axle would be spinning inside the unlocked free hub. Is there a way to test this before i go and get some new hubs?
neither front wheels are spinning at all when on grass, wet mud etc. My auto hubs no longer make a disengage click like they used to when i did have all wheel drive. What i mean by the cv axles are spinning is that when i get someone to drive back and forwards while i look under, i can see the front left CV spins, and the front drive shaft, but not the right. If power is going to one side but not the other, wouldnt the open diff mean that i get zero power at either wheels?
Sounds possible. The killswitch was installed well befor i broke it, presumably because they are pretty easy truck to break into. This issue has only been since the alternator was installed by local garage.
Sweet. Where's the fuel pump on a z24? Will badger a neighbour for a volt meter
Battery is a week old. Exactly that happened with the garage installing two alternators before giving up. When I turn the key, the battery light comes on, it starts and runs fine but the light won't go out. Turn the key off and take it out doesn't stop the engine. Luckily there is a kill switch installed. I'll do the earths and maybe change the fusable link. Brown wire feels a bit rubbery. Thanks for the advice.
As far as I can tell is ok. Not got avoltmeter atm though. Last time I checked I was only getting power to the left hand side of the main relay by the battery. Would that indicate fusible link? It was at a garage who said they could keep working on it as long as my wallet was botgomless so I had to decline.
Passenger front external door handle broke
Meatsac replied to JusticeCrew's topic in 90-95 WD21 Pathfinders
At least you didn't have a stranger break yours. -
