Tony1
Everything posted by Tony1
  1. Finally got my truck running again, changed out the MAF sensor and is running like the devil!
  2. This weekend 1. Switch Wireset 2. Spark plugs 3. Fuel Injectors 4. Painted Stock Rims Matte Black Some Pics
  3. alright thanks for the help, i´ll take a look at the link and do some reading..
  4. Okey i´ll take a look at the center console. I didn´t check the miles on the truck but i´ll take a look at it and i´m not getting the hold donor truck because the guy that has it told me he would the the job of switching out the transmision, he has a little shop so i guess i´m good there but i was thinking of getting it. The bad thing is i can´t test drive the donor truck the guy took some parts from the engine and is setting on bricks, has no tires on so no luck there and the guy that has it bought it for parts. One question, when you say lots of miles what is the approximately number of miles for rebuilding the transmision? Other then that recommend using GL-4 oils or under, thanks for the suggestion and information much help. I´m still looking for a automatic tranny but if i can´t find it this week i´ll do the manual tranny swap.
  5. My transmision started giving me problems a while back, didn´t want to run in Drive i had to shift to 2nd so it would run and after a while i could switch back to Drive and it would run perfect. So i started looking for a replacament and had no luck finding one specially were i live (i´m for mexico) but today just my luck i found a donar truck a 91 XE V6 5 Speed Manual tranny ( mines a 92 XE V6 Automatic) same Engine Model VG30E, i don´t know much of the donar truck other then that. So i have i few question, doubts, and suggestion.. so what from what i been reading it is possible the tranny swap, right? and if it is what parts are require to be swap? are this good transmision, the 5 speed? what should i look for to see if it´s in good condition? and is it worth it? PS. i´m no mechanic so take it easy with me and that is why im asking this question but i am really excited about this, ill start the process next week and i´m not doing the swap because i have no time.
  6. okei i guess i´ll start searching for a replacment, thanks for the suggestion
  7. hello i have a question or more like a problem, so i just bought my first pathfinder it´s a 92 XE V6 2WD Automatic a few months ago and just like a month ago my transmision started giving me problems. So the problem is the truck has to heat up so the transmision can actually drive in Drive has anyone had this problem? or know what it might be? is it better to fix it or too replace the transmision? P.S. if i put in in 1st or 2st it will advance okei, sort of...
  8. Just bought a 92 Pathfinder XE V6 2WD, wondering how much i can do to it, i´ll gladly receive any suggestions!
    1. Cuong Nguyen
      Cuong Nguyen
      the sky is the limit. I converted mine to 4wd. lol
    2. Tony1
      Tony1
      NICE! was it a hard process?
