Slimshade1
Everything posted by Slimshade1
I put new shocks on my pathfinder the old ones were blown but the ride is still pretty bouncy only did rear shocks because front seemed good. Any idea as to why it would be bouncy Sent from my SM-G900V using Tapatalk
Stick Sent from my SM-G900V using Tapatalk
I usually hose clamp it to the pole so I'll just do that. Then I take it off if I go on the freeway and the cops here usually wave at me when I'm going down the road I'm in arizona Sent from my SM-G900V using Tapatalk
I always called them zip ties Sent from my SM-G900V using Tapatalk
Thanks lol never heard it called that Sent from my SM-G900V using Tapatalk
Found a intake boot at a junkyard for 27 bucks so I picked it up we will see if that fixes the issue Sent from my SM-G900V using Tapatalk
What's a zap strap Sent from my SM-G900V using Tapatalk
It's my intake tube it's keep ripping more and more Sent from my SM-G900V using Tapatalk
So when I started this morning I didn't let it warm up I just started it and went and it fell pretty hard on its face but I just kept it running and it drove fine ant idea on what to fix next Sent from my SM-G900V using Tapatalk
Where can I mount a flag at on my 92 pathy. I want to put a pole up maybe 2 I had a fiberglass cb antenna that I used but I took that off it didn't work well anyway. What are some options I have Sent from my SM-G900V using Tapatalk
Seemed to fix it bought some maf cleaner and put more tape around my intake tube and it has quit doing and I made it up some pretty steep hills Sent from my SM-G900V using Tapatalk
So I let my mechanic friend drive it yesterday and he said it's a motor mount and when the motor gets pulled on it pulls the throttle cable Sent from my SM-G900V using Tapatalk
Okay will check it thanks how tight should it be Sent from my SM-G900V using Tapatalk
83.00 online Sent from my SM-G900V using Tapatalk
Mine isn't much of a hard start it starts fairly easy it just happens when I back out into the road and get on it, when I'm turning and get on it or when I'm going up a hill Sent from my SM-G900V using Tapatalk
Couldn't find the intake hose at the junkyard I found one off another nissan that looked close but didn't want to buy it and it not work I'm not sure on the model of car just know it was a 4 banger. My grandpa has some MAF cleaner would that work. Sent from my SM-G900V using Tapatalk
Only will do yea there is some cracks in the intake tube it seemed to be glued but when I pulled the filter out one day it cracked again and would barley run so I wrapped it in tape I'll try and go to the junkyard today and pick an new one up and I'll get some new Vac lines I'm sure they are rotted Sent from my SM-G900V using Tapatalk
Will do thank you Sent from my SM-G900V using Tapatalk
I'm having a issue with my pathy it's a 92 xe 3.0. when I start it in the mornings it shutters real bad and tries to stall. It also does it when I'm making turns and I have to get on it to get out of the way It will do it so bad to the point the tires will start coming up off the ground. Also when I go up steep hills in the dirt it looses all power any idea on what the problem is I've tried seafoam already to clean the injectors I put half the can in the engine from the brake booster line and half into the tank it helped a bit but it's doing it again Sent from my SM-G900V using Tapatalk
Thank you now I gotta figure out my shuttering issue Sent from my SM-G900V using Tapatalk
What up friends, haven't posted in awhile!
Slimshade1 replied to Azbuilt's topic in 90-95 WD21 Pathfinders
What's up I'm in az too Sent from my SM-G900V using Tapatalk -
Yea a pole would work mount it to your spare tire rack or back bumper and thank you Sent from my SM-G900V using Tapatalk
I have a fiberglass cb antenna and I just mounted it to that with hose clamps Sent from my SM-G900V using Tapatalk
Idk why it posted 3 of the same ones Sent from my SM-G900V using Tapatalk
What's up guys I'm from Mesa az, I got a 92 xe pathy picked it up for 900. it's got 223xxx miles but still runs great. I like it alot I want to meet some people with pathfinders I like going wheeling quite a bit Sent from my SM-G900V using Tapatalk
