Everything posted by kev9180
Ah man that's awesome. Looks like my pathfinder without all the rust spots lol. Is that a 1990?
- 8 replies
- WD21
- Pathfinder
(and 5 more)
Tagged with:
Headlights go out when I turn right -_-
kev9180 replied to kev9180's topic in 90-95 WD21 Pathfinders
Slarti, yeah the hold down is busted. I don't even see where there would be one. My battery is just sitting on top of a metal looking plate it looks like and sliding around. The little plug that the headlight wires connect into off of the positive terminal is where the issue is. Those cables keep coming a bit loose -
So with further inspection it seems to be that the two wires that get power to the headlights from the battery are a bit loose on the actual terminal that comes right off the battery. When the battery slides whenever I turn, the two wires coming off the terminal shift which cuts power to the headlights. Don't know how I'm going to secure the battery but I'm going to try and use some electrical tape at the least to further secure the headlight wires in the plastic terminal that connects to the battery. Hopefully that way I'll keep my lights even when the battery shifts. -
Terra, I took it apart and everything looks sound in there, clean and surprisingly in tact. Just got the new headlight/turn signal switch as well just in case. -
Just checked and the battery does move around on its platform, how did you fix it? I had no idea that that would affect it, thanks! -
BTW the filaments on both the headlights are fine,and if I turn left the lights usually come back on. -
Like title says, when I make a right turn, both my front headlights go out. Everything else works, tail lights, cruise control, brake lights, etc. I replaced my turn signal switch thinking it was that but nope, same problem. I took apart the steering wheel cover a few weeks ago and was good for a few days but problem is back. What do I do? If I get a multimeter and test for power (never used one), how do I do that? I'm on my last nerve with this one lol. Thanks guys
Its the bottom right pole in the picture, its basically just an enpty port that doesn't have the little piece in there that keeps the wire in place so it can touch the other piece on the male harness
Brake light/ running tail light not working due to the pole where the wire goes not conducting electricity. The crimp(?) that holds the wire in place isn't in there so its not making contact with the other end for the lights to work. What should I do for this? New wire terminal? http://imgur.com/kBq8zzb
Also, MT90 helped me a lot as well. Smoother shifting and don't notice the whine. I just got the vehicle last month and changed the mt fluid as soon as possible though
Really hope I can get another 3 years out of my pathy to get it back to Tucson. Desert weather would be so much better than out here in western Illinois
B, I think Daczone may be talking about doing a complete drain and replacing all ~5L with redline mt-90 the expensive stuff. In my case I bought the gallon jug and 2 quart bottles and it came out to just over $100. But even so like you said, he could get some cheaper stuff that would probably still be better than nothing!
If you're transmission is whining, then the consensus seems to be that you're are best off just parking your truck and doing all the necessary work now, as it's going to go sooner or later. Check out the manual transmission TSB for more info, the very first main post has all the info. Other than that, iirc the thread also said go ahead and overfill it. That's my reasoning at least, I don't have the money or resources for the full transmission fix at the moment, so I drained it and refilled it with the proper amount in hopes of getting some more life out of it!
Okay I got it all changed. Hardest part was definitely getting the carpet cuts to get the bolts free. Had to make more cuts than I wanted but can't really tell when it's all tucked back in! PS... Don't forget the zip ties! Lol
Thanks, I found a site that's got a great walk thru on that part. http://beergarage.com/PathTransmission1Remove.aspx It's like mid way down the page!
Before i start making cuts, where are the bolts i will need access too and where exactly should i cut? Are those little plastic pieces near the side of the boot what I'm looking to get out?
Thanks for the tip! I'll give it a shot tomorrow on the day off. Makes it a lot easier than having to take out the seats and carpet, etc etc.
Sweet, I'll have to do that for easy future changes. Any way I could do it without lifting the carpet/seats up in the first place?
B, what were the cuts for? Easy access for future changes? Daczone, the consensus seems to be that if it's whining, it's already screwed, and will eventually (keyword) need the rebuild, etc. I've got the whine as well but until I can save up more money I'm going to overfill and hope it extends my transmission life as it has with some others.
Okay, sweet. Those little screws are giving me issues too. Keep turning em but they won't come out -_-
Dumb question but I'm a newbie so bear with me! Went to change my transmission fluid so I could overfill it but couldn't figure out how to get my carpet up to be able to fill it through the gear shift. Any advice or a guide anywhere? Then I tried to fill it by jacking up the passenger side but realized I won't be able to just pour the stuff in there due to the tight space. I'm going to need a fluid pump if I do it that way, right? Am I missing something? Thanks for any help guys. Much appreciated.
Manual transmission TSB
kev9180 replied to madkiwi's topic in Technical Service Bulletins & Recall Information
Regarding getting the carpet up to free the boot and gear shift, is there a guide anywhere on how to do this? I can't seem to figure out how to get up my passenger side carpet without tearing it up. -
I switched out my dash lights today with some led's i got on superbrightleds.com, like some others here have done, and it was super easy. My dash lights were really dim and low before but they're perfect now. I got 4 of the 194 LED Bulbs with the 120 degree beam (https://www.superbrightleds.com/moreinfo/wedge-bulbs/194-led-bulb-1-led-wedge-base/197/#/attributes/30) in the cool white color.
I got down there this morning and got out the grass/dirt. Man, you were right it was packed tight as hell, and there was a lot more than you can see in the pic, so it must have made contact with a hill or something at some point. Got it all out, and while I don't really know completely what i'm looking at down there, everything looked okay as far as i can tell. Although, there was a seal on each of the torsion rods where they connect to the frame(?) that were both cracked and nearly coming off the torsion rod. I'll get down there a little bit later today and do some measurements (once again, thanks for those references hawairish!) and try and take some pictures. as well.
Have a great holiday everyone! Stay safe and enjoy the things that you love most. Cheers
