anzaman
Everything posted by anzaman
  1. Change my login name
  2. Thanks, it was the bulbs. There are no fuses specific to the corner lights. However, they are controlled by the turn signal/light switch, which I determined was working properly.
  3. The corner lights on my '98 are not working. I cannot figure out which fuse/relay it might be. Help?
  4. Thanks Rebelord and Karmann for the advice. Just got done replacing bushings and fixed my steering problems.
  5. Haynes manual is rather vague on this procedure. Can I replace the bushings without taking the entire rack apart on my '98?
  6. Should there be any "play" between the steering column transfer gear where it connects to the rack and pinion unit? If so, how much, and if not, is it the result of a bad gear in the unit? My steering is "sloppy".
  7. You should replace front/rear sway bar bushings/links,rear upper control arms, trailing rods, and panhard rod. It cured the "death wobble" on my '98.
  8. I have about a 1/4 to 1/3 of a turn play in the steering wheel. Can I adjust this play out?
  9. Thanks. I'm getting the same clunk and I will check the sway bar.
  10. Just did this on my 98 in the spring. Yea, the pulley needs to come off. Just take your time, double check everything as you are putting it back together and everything will be fine.
