5
CO_pathfinder last won the day on July 7 2015
CO_pathfinder had the most liked content!
About CO_pathfinder
- Birthday 04/12/1995
1991 Nissan Pathfinder XE "Vail White," now kinda faded with barely any clear coat Been in [s]two[/s] three accidents: Rear ended at low speeds, lightly bent rear bumper. Hit someone from behind, crumpled hood and rad support, has since been fixed. Rear ended again, got $300 from the guy in cash and used it to buy beer for a party. White grille, needs retouch Cracked right corner marker, courtesy of a Lodgepole Pine Dent in FR quarter panel, and FR door. 31 Cooper Discoverer on 02 Tacoma Rims (ALL WHITE NOW) Rapist red interior with blue 97 center console and console pocket beneath radio Rust everywhere underneath, and a pretty hefty dust/mud coat on everything. "Unbolting" things doesn't happen, they all just break Stock suspension, maybe someday it'll get lifted and updated. 97,xxx on the clock(pretty low score so far) Xterra rack, shorted to sit closer to the roofline Radar detector wired through the A-pillar Winter 2016: -Driving lights added to bumper next to/above license plate -Rewire interior, update lighting, make wiring safer More to come, hopefully someday will find an LSD with the same gearing ratio...
16-21
XE
1991
Gender
Boulder, CO
Country
CO_pathfinder's Achievements
NPORA Old-Timer (5/5)
66
CO_pathfinder replied to RedRider3141's topic in The Garage
Anybody have any idea what the size of the wheel bearing lock washer screws are? I had to drill all 4 of them out when replacing my ball joints - some shop at some point stripped them all and just left them there -
Ended up unbolting the centerlink at the pitman and hammering it down for an extra inch of clearance; made life 100 times easier and only took 15 seconds after I did so. Thanks for the input guys -
Anybody have tips for yanking the starter over the centerlink? mines stuck on it and im trying not to unbolt the pitman -
Most things can't be replaced/repaired by Joe now because of tech advancement. Its a good thing, I promise. Don't know if the starter is OE or not but its caked in oil so I would venture to guess the answer is yes. Ill give it a hammer smack and see what happens. -
Clarification on my issue starting - I get the "single-click no-crank" issue, which on a manual can be caused by the starter, the starter solenoid, or the starter relay (and only these things, right?) It started with a very slow crank in a parking lot, followed by half-cranks until the starter stopped responding in another parking lot. -
Went back in, and upon second inspection noticed something.. the BWD replacement injectors (along with the Hitachi OEM exact duplicates) DONT come with the 3rd of 3 O-rings. There is the ring that seals intake from injector, injector from top of fuel rail, but there wasn't a replacement O-ring for the bottom of the fuel rail leading to the intake port. Not sure if it was because of this missing O-ring or if the injector actually was bad, but the truck ran like a top after doing so. However, the rich condition caused two other things to happen: IACV is now clogged and truck doesn't like load at idle as a result - just need to degunk it. Hard cranking starts when the injector was wonky ended up killing the starter... yippee... Haven't ever even considered looking at replacing this part, so it looks like I'm going to the FSM and to the forum archives. On that last note, is the starter a job I can expect to do myself in a few weeknights after work? Or, should I pony up the $$ and make it a shop's problem. Looking for advice from those with experience. -
Considering that it didn't do this before I replaced my injectors last weekend, I'm leaning towards it being a faulty injector. Hopefully the parts store will honor some sort of warranty policy should that be the case. I'll find out this weekend -
Pulled plug, fouled like crazy. Replaced the plug and within 20 miles it was fouled again, missing the whole time. No codes, new plug wire didn't change anything.. noticed that when I pulled the 2nd fouled plug, it was clean on one side and blackened on the other... Maybe the new injector is bad in some way? -
Replaced injectors , screwed up a couple of the vac lines, truck ran like... my truck. Put vac lines where they belonged, truck ran the best it ever has for me.. for one day. Current status: Hard starting and a constant miss on cylinder 3. Its spark related, as pulling the wire doesn't change the miss but does mean rich smelling exhaust (which at least means my new injector isn't buggered) Expected solution: PULL CODES FIRST, then pull the plug, regap the plug, clean the plug hole, try a different wire, clean/replace distributor. If that doesn't fix it, I might choose to kill it with fire. As always, input is always appreciated - btw, truck recently rolled past 100,000 for the first time. -
The first grinding noise gets faster as i speed up while turning. -
Some new noises coming from my Pathfinder but I can't tell what they are because they only occur while I'm driving. First noise is a slight grinding/metal on metal rubbing sound when I turn the wheels to the left, usually between 10-30 mph. Wheel bearing/hub? Second noise is a very similar noise, almost like a bad bearing, that only occurs in 3rd gear at around 3k rpm (haven't noted the speed).. How do I check my wheel bearings in my own driveway? -
whaaaaaaaaat -
Avoid the BFGs anyways, as people have been reporting a bunch of sidewall blowouts recently at highway speeds
I spent the money on gaskets for my manual hubs instead -
On the topic of wipers, I usually just spend the amount of money that I would on two, on just the driver side, so that I can see extra good.
