00R50TN
Everything posted by 00R50TN
  1. I also found this one http://www.ebay.com/itm/332062584502?_trksid=p2055119.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
  2. I just wanted to leave this link for anyone looking for an affordable lift option with no modifications or cutting springs. http://www.ebay.com/itm/like/272184355320?lpid=82&chn=ps&ul_ref=http%253A%252F%252Frover.ebay.com%252Frover%252F1%252F711-117182-37290-0%252F2%253Fmtid%253D1588%2526kwid%253D1%2526crlp%253D177563030527_324272%2526itemid%253D272184355320%2526targetid%253D340556463047%2526rpc%253D0.14%2526rpc_upld_id%253D113993%2526device%253Dt%2526mpre%253Dhttp%25253A%25252F%25252Fwww.ebay.com%25252Fulk%25252Fitm%25252Flike%25252F272184355320%25253Flpid%25253D82%252526chn%25253Dps%2526adtype%253Dpla%2526googleloc%253D9013700%2526poi%253D%2526campaignid%253D753104144%2526adgroupid%253D38706036479%2526rlsatarget%253Dpla-340556463047%2526gclid%253DCj0KEQjwtu3GBRDY6ZLY1erL44EBEiQAAKIcvvnubz3Uv6_FdvZ2lUph5siSsruq5cP8dSjtWr3xyHsaAvD98P8HAQ%2526srcrot%253D711-117182-37290-0%2526rvr_id%253D1191839095688&ul_noapp=true
  3. 2000 Pathy SE 209,000+ miles. Runs great.
  4. I mounted that size. They will fit, but will rub if you flex or hit a big dip. I just took my flares off. They don't rub anything now. That is with fresh suspension front and rear. All stock replacement. If you have different tire sizes on the front and rear it will cause transfer case gear wind up in 4wd. If that's what you have and plan on using 4wd. It will eventually wear it out. It will also drive like crap. If you refresh the suspension and mount that size tire, without the flares, you will be surprised at the clearance it will have. Wish I had a pic handy. Maybe after I get home I can post some for you.
  5. Windrock or bust this year.
  6. For the sludge, try Marvel Mystery Oil. Some people say it doesn't work and not to use it. I have used it several times with Valvoline High Mileage 5W30 Synthetic Blend. I use a Purolator oil filter. When I changed my gaskets, mine was clean and it runs like a top. No sludge or buildup at all.
  7. Suspension lift...
