Just finished up a timing belt job on my 94 Pathfinder, everything seemed like it went smooth, replaced the usual while in there such as the water pump, crank seal, thermostat, and tensioner (I used only Nissan OEM parts). I did everthing per the factory service manual.
I started it up this morning, it fired up right away and shortly after the check engine light came on. I checked the codes and got 23 and 45.
Upon further investigation I found out that cylinder #2 is not firing, I confirmed this my lifting the plug wire for #2 and no idle change was noticed. I swapped plug wires and spark plugs and the problem still remains. I did a compression check as well just to rule out unlikely event of a timing belt slip and I got 165PSI, thats the same reading I got back when i purchased the vehicle.
I am at a loss for what to do, I really don't want to have to remove the intake plenum to reach that injector. Are these injectors troublesome? They are the original injectors with 201K miles on them.
I should mention that the vehicle did sit for about 1 month during this process
