Procrastinational
    "Penny" the Pathfinder. 1999 Chilkoot, 5 speed. Rainforest Green Pearl. 268,xxx Km. 4.64 gears, rear LSD. She's had a hard life, so I'd say she's a bit of a beater. She's got plenty of scratches and a dent on the lift gate, but she's mostly rust free. She's basically 100% stock for now. Trying to decide whether to upgrade her, or wait to find a better equipped model. My ideal r50 would be either a pre-facelift model with rear tire carrier and sunroof, or a 3.5L model with a 5 speed.
    Chilkoot
    British Columbia
    Canada
Procrastinational's Achievements
  1. Hey guys. I got my winter tires swapped out today, and when I got home, after unloading my winter tires (while parked downhill for a little while), I noticed some oil on the driveway. I took a look underneath, and there is what looks like a drain of some sort missing the cap. There is some oil in the area as well. I took some pictures and I'm hoping you guys can tell me what it is, and whether there is anything missing. It is roughly in line with the front attachment points of the running boards. Btw I have a manual transmission if that makes any difference. It looks like there is still a bolt in there. Maybe it's just loose? Is a bit of oozing normal? Here are the pictures:
  2. That's the one thing I hate about my 5-speed. RPM's are very high on the highway. Mine hovers around 3500 at 80. Mind you, it'll run at that all day long if you can put up with the noise, but it's very tiring on road trips. For your use it sounds like replacing with an auto is the right choice.
  3. Hey everyone. Quick question. I was looking at craigslist and I found a '98 Pathfinder Chilkoot for sale, and I couldn't help but notice the rearview mirror has a temperature gauge and compass. Here's the picture from the ad: Original ad: http://vancouver.craigslist.ca/rds/cto/4808817156.html My Pathfinder has the exact same rearview mirror with buttons on the sides that activate the reading lights, the button on the top left (which I have pressed and held and doesn't seem to do anything), and the black area on the top. However, the part with the temperature and direction doesn't light up or do anything on mine. How would I go about fixing it? I realize it might be a hard question to answer because the Chilkoot models (and probably this rearview mirror) are exclusive to the Canadian market.
  4. If I find one, I'll send you a PM. Any parts in particular?
  5. Unfortunately the QX4 I found for cheap had a few vital components damaged when it was wrecked Took a look at it the other day. Seemed like it must have been hit pretty hard on the passenger front fender, as everything in the dash on the right side was a bit mangled, and the HVAC screen was no longer functional. I'll have to keep looking for another donor vehicle.
  6. I have a pre-facelift 99 so I can't really help your poll... I didn't even realize there was a key cylinder on mine However, from google images, all the "2001's" that have one look like they may be 2000 models being mislabelled. Either way, definitely none from 2002 onward, so my guess is 2001 it was changed, but it could be a 2001.5 change as well...
  7. Thanks for the info Very helpful. I guess I'll just have to see what prices are like compared to the Duratracs when it comes time to swap out the winter tires this spring.
  8. Good to hear. The way I see it, my Pathfinder is already pretty noisy on the highway (4.64 gears and the manual make for some pretty high revs), so I'd probably barely notice a bit of extra tire noise. In fact, going with 31's might even drop the revs enough to make it about a wash for noise. Thankfully I'm not on the highway all that much though, and I'm a fairly laid back driver so I'm not too worried about a little less acceleration. I've heard only good things about the Duratracs, but I was considering the KM2's as well because, as you say, they look pretty sweet, and I'd imagine they're a bit better in the wet mud/soil for the wet months on the BC coast.
  9. How are they for on-road handling and noise? I've heard they aren't bad for a mud tire... I'm debating between a set of those or Duratracs. I already have dedicated snow tires so winter performance isn't important thankfully.
  10. Good to know with the condenser. At the very least I could swap that, and then maybe the seats (and probably the carpet so that they matched). And then the door panels, which would mean all the interior panels except for the dash... Amazing how quickly DIY projects can escalate in scale Would the tail lights be a direct swap? I know the post-facelift ones have separate reverse lights, but how about the 97-99 models? Normally I wouldn't bother attempting something like this, as it would be complicated to source every part necessary. However, in this case every part I need should be on the qx4, right? Meaning all the wiring harness and sensors... Does the base model come with the necessary mounting points pre-drilled and empty? Seems to me it would be cheaper to make a car the same across all models for that type of thing. I was also debating swapping in the overhead console, but I figure it might look tacky to have sunroof switches and no sunroof. I noticed some facelift models have an overhead console with the temp/compass but no sunroof. Would one of those work?
  11. I searched and found one thread on this, which ended before much useful information was shared... I found a very cheap '98 Qx4 in my area that I was considering for parts. What I'm wondering is how challenging it would be to swap over the digital climate control? I'd have all of the parts, I'm just wondering if it is some massive task, or whether it's a fairly straightforward swap and drop. In case that's too challenging, another related question: my AC condenser has been toast for a while... would the AC condenser from a 98 qx4 be the same as the one in my 99 Chilkoot (basically an XE) model?
  12. I didn't mean to make it seem like it was grinding every shift or everything. Going into 5th it maybe grinds once a week at most, and 1st, as long as I don't rush, there is no grinding at all. For now I think it's still in the wait and see stage. It's still at the point where the grinding is avoidable if I shift more slowly. Interesting about the brake pedal. I would guess that my clutch pedal has about twice as much resistance, especially in the midrange of the travel. It gets a little lighter over the last inch or two when pushing it in. I believe I had the transmission fluid changed sometime this spring. So I doubt there is more than about 10,000 Km on the fluid. I'll have them check the fluid just to be safe. Thanks. Is there a way to visually inspect it from the outside? Any common leak spots?
  13. **** Scratch that I was thinking of transmission fluid. Need another cup of coffee it seems. Where under the hood is the master cylinder?
  14. First is fine unless I am at a complete stop and try to go from neutral to 1st in a rush. In that case it'll grind a bit on the way in, but it goes into gear just fine. Also: Not a mechanical issue, but I find it really hard to find a nice seating position because I have to be close enough to fully depress the clutch (very long travel), and yet that puts me a bit closer to the steering wheel than I'd like. If I sit further from the steering wheel in a comfortable position, I have to stretch to get the clutch in all the way.
