About nathanholtgrewe
- Birthday 08/25/1983
'98 Pathfinder, 4" Krypton Sub Frame Drop, 2"AC Coils in front, Jeep Lift Springs in the rear, WJ Custom Bumper install with 12000 lb. Badlands Winch, Custom snorkel
30-35
1998
Contact Methods
Website URL
http://www.ExtremeElectricAZ.com
Gender
ARIZONA
Country
nathanholtgrewe's Achievements
Yeah, I have a login. I have ordered from them before for my last pathfinder I lifted. But at checkout, it says, online orders aren't being taken. I also emailed them with no response. I hope I can still get these parts. I already ordered everything else to go with it. Is there anyone else selling a kit like it?
Has anyone purchased the 4" sub frame drop from krfabs recently? I am really wanting to get a lift on my new pathfinder but the site says no online ordering. Anyone know why that is?
Mechanical Locker for Rear
nathanholtgrewe replied to nathanholtgrewe's topic in 96-2004 R50 Pathfinders
And yes, this is also where I got mine. They had them on sale and a coupon code for another $100 off. Just happened to be looking at the right time. Works great! -
https://www.4x4parts.com/nissan/complete-detroit-locker-assembly-p-5024.html The above post was in reference to this link. would it work? Says all h233b with or without LSD and 31 splines. -
Would this one not work? Based on the description, it seems it would? -
So I changed my own timing belt......
I ended up gettting all I needed from a junkyard for next to nothing. All is good now. A learning experience, but at least not a costly one. Thanks for all your input. -
35" Tires without re-gearing?
The VQ means you have the 3.5 liter I assume? -
Does the master kit include all that is needed? Anyone have an idea what labor for something like that would cost? And it would still work with my front locker? -
I pretty much got it all I think. It came with brake lines, panhard drop bracket, extended steering knuckle, spacers for rear, and of course the 4" drop blocks. Then I ordered the Jeep springs for the rear, got the AC coils for the front with new struts and shocks. In the rear I got some Ford F350 Shocks. All works great with a total of about 6" of lift. I am glad I went with it all. My truck is really a beast now. The FAQs on the Krypton website helped me decide everything to buy.
I also have the 4.3 gears, but with the 3.3 Liter. Will there be much of an improvement to make it worth it to go 35s if I am not going to re-gear anytime soon? I like the look and always want to go "BIGGER!", but mabye its not worth it. I am thinking of the extra inch of height and clearence in the middle, but maybe it isn't worth it. And if I did re-gear, which gears? 4.88, 5.13? -
So I have been running 33s with 6" lift for a while now and I want to upgrade to 35s. The 33" upgrade already made the truck slower and pretty rough climbing hills on the freeway. Is it going to be a lot worse with 35s? I don't mind it being slow but I want to be able to get up North and I am not willing to drop the money to re-gear yet. Any input? I know a couple of you guys got 35s but didn't know if you had stock gears.
Its for the rear end. The spacer is also an adapter that allows you to use jeep springs on the rear. I used the entire kit and think it was a great deal. Saves a lot of time in trying to make your own linkage and panhard bracket, etc. I've been very happy with mine.
So I got some of this figured out. I took everything apart and I made a pretty good size mistake. The tension was okay. I put the washer that goes behind the harmonic balancer in front of the cover instead of the back. The result is, belt is ruined(I got a new one), the cover is bent up, and the washer or plate is tapered now like a cone instead of a flat washer. I am pretty sure it is supposed to be flat? So now, I am having a hard time finding a new lower cover and the washer/plate. Any ideas? Thanks again. I know this is a novice mistake, but my goal was to learn and it is working! -
To be honest I didn't know there was a setting of the tension. I just put the new spring on the new tensionor back the way I took it off and tightened the bolt that holds the tensioner there. I figured the spring set the tension level. I really feel like the burning was something rubbing, maybe metal to metal and then it wore through something to make it stop. When it was smoking I thought I saw something glowing a orange red color at one of the front pulleys. Didn't get a good look since I immediately turned the truck off. -
Hi guys, After finding out I could save $500, I decided to do my own timing belt on my 98 Pathfinder. My first time, but I am pretty mechanically inclined, I got the book and watched a few videos, etc. I got through all of it okay. I am sure I got the belt back on right and there were no real issues. I start it back up and it runs fine but starts smoking right away, so I turn it off. Then I ask a friend to start it so I can look under the hood to try and see where the smoke is coming from....Smoke it gone now!!Seems to run fine...But it is making a little bit of a higher pitched whining noise that it never did before. I don't want to really drive it until I know it is okay, something was definitely burning something to begin with, seemed like metal on metal. One thing I noticed during the install was the new tensioner I got did not spin nearly as freely as the old one, could this mean anything?? Thanks for any advice.
