FindMe
Everything posted by FindMe
  1. Replaced pass rear wheel cylinder and made no difference
  2. I haven't replaced brake shoes because they look like they have more than plenty of pad left.. will take drum to parts store for measurement A friend just gave me a Haynes manual and it mentions a load sensing valve.. could this be a possible source of problem?
  3. yes I adjusts the star wheel out as far as i can and still able to get drum back on.. yes there is a little drag on the drum. I made certain i didnt get any brake fluid on pads.Also sprayed with a whole can of brake cleaner when rear of vehicle is jacked up and put into gear and brake applied the rear passenger wheel slows but never stops, the drivers rear stops but barely Could my drums be out of tolerance? would it cause it not to stop well? like I said I just bought this for a secondary vehicle/offroad toy
  4. Recently Bought 95 pathfinder Automatic xe. It'll stop but not as good as it should. Back tires will not lock up on snow. Also jacked up rear of vehicle will wheels off ground and put in gear . Passeneger wheel will not stop spinning when brakes are pressed or pumped. Driver side rear barely stops spinning. I cant even put it back into park whille running with the pass wheel spinning I have replaced pass rear wheel cylinder, adjusted star wheel and bled brakes and had very good pressure when bleeding (fluid gushed out) and still same thing. Can only get front brakes to lock up in the snow. will not lock up on dry or wet pavement. I have no lights on dash and my abs fuse is good.
