93pathyfiend
Everything posted by 93pathyfiend
  1. Nissan uses metal lines inside the frame rails until close to the differentials, then they used rubber hoses to connect to the differentials. The front and rear diff breather hoses meet up into one and then are routed up under the hood in the engine bay. This allows you to drive through water up to your hood before your differentials are flooded.
  2. I'm not positive but I think these are the same plugs Datsun/Nissan used off years. There are repair kits on eBay that come with all the plugs prewired with 6" of leads
  3. That was dumb... But anyway thanks for the advice, the more I thought about it I came to the same conclusion you did about the y-pipe... I'm just going to go with the long tube obx since my motor is out and it should be easier to snake them in there...
  4. eBay: energy suspension makes good kits for not too much. They're listed as poly bushings but unfortunately I don't have any personal experience with them... I plan on using them just because they're cheap and my stock rubber ones are pretty much gone!
  5. Sorry I didn't post a link but what do you think about these http://m.ebay.com/itm/150951542217?nav=VI&sbk=1 In combination with the stock y-pipe?
  6. Sorry hit post: replace my cracked exhaust manifolds... I also found a set of short tube headers that obx makes for the z31/z32 na vg30
  7. Do you think they could be installed with the motor out, instead of using a body lift? My motor is already out and I need to re
  8. So I am rebuilding my 93 pathy... I ordered a kit from mizumo auto and it came with everything for the TBI and MPI motors. My question is my 93 oil pan originally uses a rubber horseshoe things at each end and silicon gasket everywhere else, the kit has these rubber horseshoes but the rear one is too big. The kit also comes with a rubber seal that goes all the way around the pan... I'm contemplating cutting the horseshoe off of the seal to use but would just rather use the whole thing... Are there any real reasons not to?
