Everything posted by 4x4troy
95 pathy not starting..not like all others.
4x4troy replied to 4x4troy's topic in 90-95 WD21 Pathfinders
them same night it started having problems -
still needs work but atleast i can start it now.....oh and some jerk tired to steel it...destroyed the ignition cylinder and messed some other stuff up. so i have to treplace the steering column,door locks, and a few wiring harnesses...asshat cut a few.... but atleast he did not get it. -
no idea at all ...still looking for bad wires or whatever -
its alive......one fuse and the fusible links were replaced and she starts up......and the ac and radio work -
yes battery cables are clean and tight...has new battery. -
the ones at the battery? -
and what would cause all that happened at one time? -
ok which one is the starter relay? -
so the ones by the air filter...one of them for my starter? -
in which fuse box..under hood or under dash? -
here are some pics...the blue relay on pass side has very small wires coming out of it. -
ok i was driving on the highway and all the gauges stopped,the ac stopped and the radio stopped working...no power. i pulled over and shut the pathy off to look under hood to make sure i did not loose a belt. did not see nothing wrong so i got back in and went to start it....nothing...the relay under dash makes a click noise...thats it. i can unplug the connection next to the battery and run a jumper to it with the key on and it will start...but dash gauges still dont work nor does ac or radio.....any ideas on what to hell is going on...its a 95 xev6 auto 4x4.
under $50...its the duplicolor spray on bedliner
not really. just taped it up and sprayed it on
thanks, build wont be to bad...no stranger to fabbin stuff up.
thank you for the welcomes. it is a auto, has 189,500 on it. the black on it is bedliner i did after i got . it was all white with flairs stock wheels on front and blades on rear..
hello all,i am new to the nissan world but not 4 wheelin. i just picked up this 95 pathy. it is a xev6 4x4. i have put 15x10 wheels and 31's on it. plans are sas 4link front, long arm front and rear,build some bumpers and have fun with it. i live in jax,fl if any one is local and wants to wheelin i am down.
Need new tires 31x10.50x15 recommendations
4x4troy replied to Stifun's topic in 90-95 WD21 Pathfinders
pepboys has dakota difiniti mt's and they are great tires. i think i paid just over $500 with road haz. i had them on a tj and it worked great and lasted a long time -
SAS and engine swap WD21
4x4troy replied to daver123's topic in Solid Axle Swaps, Hardcore Custom Fab
very sweet...hows the build coming?
