Skib
Skib last won the day on January 22 2013
Skib had the most liked content!
    The shop truck and tow rig.
    Do Not Go Off-Road
    Sacramento, CA
Skib's Achievements
  1. Thought so but wanted to double check. Its a 5 speed so all good. Once I get some other projects out of the way I think my pathy needs a VG33er lol
  2. should bolt up to the stock trans right?
  3. Will the VG33ER mount in the WD21 with either the 33er mounts or the stock 30e mounts? Just working out if I go about picking one up and building it if Im going to have to fab up the engine and trans mounts or not...
  4. soaked plugs means an engines getting fuel and no spark... "flooding" if there wet enough to not start you let them dry out... its gas, it evaporates fairly quickly. if you have spark your good to go.
  5. Iv always been favourable to VDO, I ran them in my old SCCA car. there generally very well priced too, which is great when you race on a budget.
  6. where did you tap your vac line into path?
  7. summit racing carries that gauge. and I picked this one up from Napa
  8. when you do get a new starter make sure to pull a plug and check its actually sparking there. spark at the coil and even the wires doesnt always mean its sparking at the plug.
  9. well if its backfiring out the exhaust side then that tells you the timing is to retarded
