DsR50
Everything posted by DsR50
  1. ok so i have finished the SFD with 3 inch blocks and 5 inch strut spacer. I really need help with my steering linkage. Yea i could pay the 165$ for the linkage or make my own. so i went to the pick n pull and got one of those ujoints so now i have 2 total and got somthing hooked up but it binds so any ideas?
  2. is everything direct fit tho? as far as bolt up or do i need all new drivetrain?
  3. lol V8 would tear the frame i feel like, and yea it is alot of work for 40hp so maybe do it when the motor is toast. tossing a cam in there is going to suck gas worse then it already does
  4. yea i just dont want to spend the 500, i see what you mean about the exccesabilty so im thinking 3 inches might be good. as for the alignment its about 4 degrees positive camber droping the Sub frame down 2.5 with put that at less thank 2deg which is alignable. so i think 3 inches would be good
  5. Also i have 2.5 inch pipes, gutted cats and no resonator.... which sounds amazing lol
  6. alright so i decided to make a lift for the pathfinder. I dropped the struts 5inchs and i figured out the hard way that i must drop the sub frame. so i like the amout of clearance with just the strut spacer, but the lower A arm angle is a bit extreme. so i need someones opinon on if i drop the sub frame about 2.5 inchs so i can still get a decent A arm angle if itll align and be alright
  7. Hey im doing this same thing but i dropped the struts 5inchs and i figured out the hard was that i must drop the sub frame. so i like the amout of clearance with just the strut spacer, but the lower A arm angle is a bit extreme. so i need someones opinon on if i drop the sub frame about 2.5 inchs so i can still get a decent A arm angle if itll align and be alright
  8. yea theres quite a bit of wiring modification that goes in to the super charger, id rather turbo it. as far as the EGR vacum i will be pluging that. it will set a code but gives you a couple horses
  9. thanks for the input! every thing helps
  10. we all know these things arent made to race but i still enjoy getting on it and making that waisted gas well spent with the adrenaline that flows. I also own a 13 sec 1/4 mile 71 lemans (not crazy fast but fun to drive) so making a pathfinder try to satisfy those standards :laugh:and hard but i think possible so whats out there. Cheap easys or alittle money spenders that keep this engine or another engine that is direct fit
  11. alright how do i tell the differance, in the future id like to run manual locking hubs and id rather have the tx10 rather then the auto version cause i know the auto one has 2 pumps and causes a problem if you were to run manual hubs
  12. Sweet thank you, how do I tell if its the tx10 or another tcase?
  13. hi there im new to the cite, so sorry if im in the wrong area. My question is when i do the swap do i need the tcase from the manual tran? or are they both the same. any one done this swap that ran in to some big problems?
