shortysmash
shortysmash last won the day on April 16 2016
shortysmash had the most liked content!
About shortysmash
- Birthday 07/31/1984
2001 Le
Skilled/Experienced Mechanic
2001
Gender
Shallotte, NC
shortysmash's Achievements
NPORA Regular (2/5)
I guess what im looking for: ability to do well offroad. I dont go wheeling alot or much like that but for when i go camping etc. as far as aftermarket im not too worried about that either I know that the wrangler has a huge aftermarket and i saw the fj has a fair amount too. however i probably would be doing much as far as lift and tires becase right now i live at the beach so not much wheeling territory. Luxury things i like just because thats what i have in my pathy. but mainly i just want leather. so dunno if that helps or not.
well the pathy starting to show her age. Im looking to getting another suv. if you could get another suv but not the same pathy you have now what would you go with. im trying to weigh the pros and cons of the few im looking at. 08-09 Pathfinder 08-09 maybe 10 Jeep Grand Cherokee or commander or Wrangler 4dr(although highly underpowered) Toyota FJ 08 09 4 runner any other suggestions. Does anyone have any experiences with these and if so what are your pros and cons.
Rear Main Seal poll ( weighing options)
shortysmash replied to shortysmash's topic in 96-2004 R50 Pathfinders
Its an automatic -
general condition of the car is pretty good. no visible signs of rust. everything else is in great working order. just some minor trim repairs are needed like the strips that fill the gap between the body and fender flares, but other than that its just high mileage. -
Knock on wood. The only thing major was a transmission at 135k. and the tune hasn't changed yet but may in the next few months with budget cuts at work and what not. a.k.a will i still have the job im at -
I got that quote from calling around to some transmission places. They seemed to be cheaper as they are used to pulling the trannys etc. Unfortunately its an automatic. Yeah i was originally considering selling for a while as its high in milage and the value is going down. so i figureed trade or sell while its worth a little. Also the can of worms is just the fact that its almost 200k and once you start moving things that havent been moved befrore things could start going bad, i was just afraid that by doing so more things would start going bad like other seals, the transmission or anything and everything. -
Ok heres the scoop. I have an 01 LE with 198,000 mi. on the clock. Ive ran mobile1 full syn. for past 5 years. I believe my rear main is the culprit as i see oil dripping from around the inspection port at the rear of the oil pan. The size of the leak is about a the size of a quarter after i park it for a day. Now I now my options are 1)Let it run with the mileage as high as it is and add some lucas and some bars stop leak. 2) Replace the seal 3)Trade/sell get a different car and have a dreaded car payment. The lowest price I have found on replacing the seal is $671 which would be about 2-3 car payments. Or if i change it would i be opening a can of worms. So now im just stirring the pathy pot and seeing what comes out. Thanks
Now by oem hid are you talking about getting a hid conversion kit or did your pathy come with hid already
ok so i searched but couldnt find anything current. without going the full hid conversion route what are the brightest/ whitest headlight bulbs out now. for the past few years i have used the silvania silverstar ultras in my pathy and have been pleased. But as it always happens i lost my driver low beam abut have highs so its time for some new ones. any suggestions
Is that supposed to be 8w90. isnt there a big difference between 70w90 and 8w90.
Well i went to advance to get some fresh gear oil for the old girl and they asked what type diff i had. I wasnt sure if it was limited slip or just a regular diff. So i didnt buy any since i know that limited slip diffs also require the additive. does anyone know how i tell and how much and what weight gear oil i should buy? i know to fill it up till it runs out fill plug, but any idea how many quarts that is i searched but found a couple differnt numbers
it sounds like a bad solenoid. especially if you can still lock and unlock with the key. but if the key doesnt work then maybe the rod that goes from the solenoid to the lock has broken or come loose. That happened to me once and i couldnt open the back hatch at all. i had to crawl into the car and try to dismantle the back cover and whatnot.
Bose System adding a subwoofer?
shortysmash replied to Chicano2005's topic in 96-2004 R50 Pathfinders
yeah the line out converter is the easiest choice. Now on the other hand if down the road you decide to add an aftermarket headunit be aware that no matter the Watts the headunit puts out, the built in amps in the oem bose speakers will limit your output as far as loud etc. so the best thing to do in that case is bypass it and run new speakerwire and put in new speakers. Its a true P.I.T.A to do because you have to remove all the trim etc... but its def worth it in the end and the sound quality is a hellova lot better. so just some food for thought. -
One option will be to add a line output box i think thats what its called. but basically its a box that you splice into your speakers to give you RCA outputs that you can hook up to an amp that is hooked to the sub.
