tdauria last won the day on November 7 2022
tdauria had the most liked content!
1987 Pathfinder SE 4x4 5Spd Red [Been in family since new, 198,9XX] 1995 Pathfinder XE 4x4 5Spd Charcoal Pearl Metallic (KH2) [Bought used in 2011, 120K]
16-21
XE
1995
Gender
Long Island, NY
Country
tdauria's Achievements
NPORA Veteran (3/5)
27
Weird, random poll, ALL R50 Owners please contribute...
tdauria replied to ferrariowner123's topic in 96-2004 R50 Pathfinders
2002 & 2003 no pass side lock cylinders here both SE Sent from my iPhone using Tapatalk -
Looks like you went to a firestone? Thats the printout i always got from them. I had the 'lifetime alignment' on my wd21 and just a heads up they only did toe. I was way out of spec on caster i think and they told me they couldnt do anything about it and it would always be like that. I tried many times to explain that the fsm clearly shows procedure for adjusting it and I always got another excuse like oh you need SHIMS? Thats not an alignment that wouldnt be included if we could even do it. Also witnessed a tech take a torch to my tre to free up the lock nut and melted my cv boot a bit.. Sorry for the rant but just wanted to give a heads up on this. I had a couple other shops mention the 'toe and go' firestone shennanigans as well. Maybe i just had bad experiences by chance but figured it was worth mentioning.
When you love your overly square tank-on-wheels so much that you sneak a little drawing of it into the app you're designing
Ive only had one so far, but that was probably due to insufficient silicone on the threads of the screw. I unscrewed the bolt/screw in question, applied some 'windo-weld' (i think it was called that or something similar, a type of black windshield sealant i had on hand) screwed it back in and back to leak free. One thing to note is that the xj rails are meant to be mounted on a level surface, but the spot I chose was angled out a bit, so the crossbars don't sit quite perfectly. I'll grab some pics and follow up with an explanation, without them I'm pretty sure ill be about as clear as mud lol
Good info, from the website it sounds like they're pretty open to working with whatever the customer would want. oh man the things I would do for that motoiq pathy lol for a while I knew more about that thing than my own pathfinder from reading those posts xD good to see it's with a forum member
I'd like to stay on the side of *most likely* possible, but absolutely agreed; the realization of having to deal with more O2 sensors had me running immediately.. Definitely on my to do list, my mechanic tends to check/tighten them as a courtesy when I bring it in for jobs I don't feel confident tackling myself, but the leak still tends to show up with a change in seasons I think. Hoping to get headers within the next year, fingers crossed everything falls into place for that --literally and figuratively. Haha maybe you're just not breathing in as much exhaust gasses anymore? Weird though, maybe it helped breathe slightly better past a restrictive(ish?) cat but still got enough gasses past the sensor to get a decent reading
Sometimes that's all that matters lol. Might mask a little bit of the manifold leak noise too! Definitely a good point with the water, I'll have to get a driver side inner fender for splash protection but other than that I generally avoid water crossings and deep mud ever since i had a bunch of mud hit the fan and well, now I truly understand the expression 'when the s--- hits the fan'.
Oh trust me, I've spent quite a bit of time drooling over the thought of doing those upgrades haha. At this point especially, I'm pretty sure spending that much on basically a tune for my stock engine wouldn't be worth it (doubly so for a broke college kid). So unfortunately we're pretty much in the same boat for the time being On the plus side, I could've sworn the POP charger cost $100+ the last time I checked. $65 doesn't sound too bad at all, and I've never really seen a negative review/comment about them only neutral or some degree of positive. I'll have to remember to do some research or inquire about an m30 POP charger, this would save me a little work as well adapting the m30 MAF bolt pattern to the pathy airbox (i think). Thanks for the input Gotcha I was never really all too clear on that, thanks!
UPDATE: Ordered last night off ebay for 40 bucks, and it's already been shipped! Time to start gathering the rest of the parts and sit behind the door waiting for ups..
Didn't even think about that. Even if adding all the sensors would make it work, it would definitely not be worth the effort for me haha Could you elaborate a little on what exactly being mapped differently means? Like air/fuel type stuff? Will be ordering an m30 ecu shortly Thanks, Tom
Hey all! It's been a while but hopefully I will be able to be a much more active user in the coming months (to each their own, but I loathe working on the truck in the cold lol) So, I have been reading up on the m30 ecu swap for quite some time recreationally like many others probably have. However, I recently realized how achievable this would be with my current experience levels with the pathy and with electronics in general. Furthermore, the swap is even more enticing for me due to the fact that I threw together some basic hardware and software to interface with Nissan Consult, and the m30's ecu supports this! One of my first questions is with regards to other ecu options. In my searching I came across some information in a forum where the VG33E ecu was mentioned in passing, which got me thinking. Correct me if I am wrong, but from what I understand, a VG33E engine into VG30E-based WD21 does not require an ecu swap. Could this mean that a VG30E could be run with a VG33E ecu? The implications of this would be not only being able to use consult, but also OBDII (been dreaming about this for years lol)... I am aware that an ecu swap will not do too much for me with stock everything else, but as a Computer Engineering student, I am much more interested in the data interfacing aspect of it (although knowing that headers,etc ontop of the ecu swap would net me more than normal is a nice bonus) and doing it as a personal challenge. Do we know if anyone has done this before? I cannot recall ever reading anything about it. Worst case scenario I do plan on doing the m30, especially as MY1PATH has provided tons more info than i would need (i'm already mpfi). Thanks for reading!
Speedbumps and potholes scare me a little in the winter, but only for fear of having to wrench on the IFS in the cold lol
..When "State of Emergency" means playtime as far as you're concerned
Hey guys, just a quick question on the stock trailing arms... I know that at some point the design was changed from a beefy looking bar to the thin little things that I have on my 95. My bushings are shot and I'm waiting on a set from AC to come in, so I'd like to know if the two styles are interchangeable, and if so, should I try and get a set of the older ones from the JY? Or will it not really be worth the hassle? I don't do too much wheeling at the moment, but I'd like to have the option when I'm finally done going through replacing old/broken stuff. So is the changed design a result of Nissan cheaping out a bit, or maybe are they weaker on purpose to bend/break before something more important does? I'm kind of clueless haha As always, all info/opinions/thoughts appreciated!
Can't really tell where that is, but when I went looking for it I found the hood release cable grommet was no longer in place. Black silicone in there and SO FAR it looks to be good enough for me! *crosses fingers*
