Pathy415
Everything posted by Pathy415
I did a write up in the NICO forum and used an extension with universal joint. A bit of a pain but eventually got it done. http://forums.nicoclub.com/how-to-replace-plugs-cap-rotor-on-1999-5-3-3l-pathfinder-t527336.html
I can't unlock the doors(drivers side) with neither the driver side master switch nor the remote. If it was one or the other I could narrow things down a bit but unfortunately it's neither. When you say door lock solenoid that's the same as actuator right? The dome light works fine if I open the door manually, it will light up or if I'm in the car and flip the dome light switch it will go on. I think the keyfob is fine since it will unlock the trunk, and the two passenger side doors on the left( if you're facing the car). I'm thinking it may be the wiring or both solenoids are out?
OK so my drivers door lock won't lock/unlock with the remote but I can still do it manually with the key or by hand(flipping the open/lock switch right next to the handle). In addition, the dome light doesn't turn on when I hit the unlock button on the remote but I can still turn it on manually with the switch from the inside or if I open a door it will turn on. I have the exact same(lock/unlock) issue with the rear passenger door on the drivers side but I bought the car with that existing issue. The issue I mentioned above just happened like a day ago. Anyone have any thought to what it might be? Thanks!!
My apologies in advance. Newbie here on this forum (usually on the Nico forum)and yes, I have a 2wd, but I'll chime in with my MPG. 1999.5 LE 2wd Auto Running Valvoline 80w90 Synthetic Blend gear oil for the diff. Gastrol GTX 5w30 Valvoline conventional ATF I've gotten a worse of 16 mpg(50/50) and a high of 19mpg(30%city/70%highway). If I'm easy on the throttle I can get 20 mpg on the highway.
OK I'll see if I can take a look at it over the weekend. Thanks!
Here's a youtube video that explains bench bleeding. You'll probably be able to find more videos, I just grabbed the first one that showed up on the search. If you're bleeding a new master cylinder I think it should come with parts to perform the bench bleeding procedure.
I've owned the car for about a year and never got around to fixing the drivers side passenger door lock. All the other locks work fine but when I try to lock the passenger door from the inside using the master switch or arming the car using the remote it won't activate(lock). Does anyone know what could be the problem other than the actuator? I'm new to this forum and have owned the truck for almost a year. Any help is appreciated!
I'll try and tackle it when I get some time. Thanks for the advice!!!
993 Porsche Turbo or C4S
lol.I probably won't be doing a conversion, if anything, I'd probably just sell my car and get a 4wd but I still like my car and since I've put a decent amount of work on it I'll probably keep her for awhile. Thanks for the welcoming!
Hello, new to this forum and wanted to see if there's a How To for the drivebelts on a 3.3L R50. I used the search function in various forums but couldn't find a walkthrough. I can remove the lower fan shroud to gain more access but it looks like the upper shroud comes off with the radiator. Also the fan itself is sorta in the way, am I supposed to pull the fan off or is it possible to loop the belts around it? I only saw two bolts where I could loosen and remove the belt but what about the 3rd belt? I'm basically doing a complete tune up and have done pretty much everything (diff fluid, tranny filter/fluid, pwr steering fluid, coolant,fuel filter, plugs, dist cap, rotor etc. etc.) except for the drive belts (timing belt was done by previous owner about 30K miles ago). Any help is appreciated! Thanks!!!
Hi all, new on this forum. I'm registered over at the NICO forums but just found this one and there's so much info here!! I hope I don't get bashed for having a 2wd LE but I'm here to learn!!!!
