BTS
Everything posted by BTS
  1. BTS
    Hid's
    thats a good idea... does you headlamp assembly still have the spot where the moisture can escape? Or did you fill that as well??
  2. BTS
    Hid's
    Does anyone have them in there pfinder?? if you do do you ever cross water?... see i wanna set but if i go out wheeling i dont wanna come to a water crossing and be scared that im gonna blow my hid's. any would be great. I was looking at alumina kits web site > http://www.aluminaxenon.com/index.html .. all kits have weather proof seals to them where they connect to another wire... any ideas?
  3. Hey Im just about to do the First Service to my R50 5 spd. I just crossed 270xxx.. I'm gonna go to the dealer tomorrow to see if I have LSD in the pfinder. Just wondering about fluids : Amounts and Type and if I need an additive; 1. Front Diff 2. Transfer Case 3. Transmission 4. Rear Diff I already did a main check over of Brakes and Brake Fluid, Engine Oil, Coolant. Everything checked out good. Also is there anything that I should also check anything else???
  4. you guys rock... i did just start checking out some lifts, cuz some of the places i have been i scrape my running boards and other things... where does everyone get there 2 " lift?
  5. application guide says they don't work for a 97 p-finder
  6. old man emu my buddy got the specs for me.... i cant seem to find anything in summit.. they have my coils at a local wrecker but they want 50 a side for labor and 100 a coil
  7. hey i have a 97 pathfinder and well the passenger side coil is broken and missing a coil. Buddy has a set for coils from a 95 p-finder and says that i can have them... only thing is that they are a bit different. 87 - 95 p-finder 14mm diameter 198lbs per 1" 430mm free 96 - 99.5 p-finder 15mm diameter 140 lbs per 1" 360mm free Which means that the 95 p-finder rear coil is almost 3 inches taller, 1 mm smaller in diameter, and can take more weight. anyone think that i could use those coils in my 97?? might even get a bit of a lift out of it?? any input would be GREAT... Thanks in advance.. Ben
