spazman
About spazman
  • Birthday 05/08/1982
    2" emu lift otherwise stock
    Grand Junction
spazman's Achievements
NPORA Regular (2/5)
  1. I got mine from amazon for $160. Looks like they're going for $155 now. Amazon $155 Warn 29091 Manual Hubs The only issue I had with mine was the grease in them somehow solidified in a couple of places making it no longer engage all the way, I thought they were engaging because they clicked but the wheel would almost feel like it was hopping. I took them apart, regreased them, put them on and it was still there so I thought it was the transfer case or front diff. But I just took them apart again this weekend and found the rock hard grease in a couple of the teeth, popped it out with a toothpick, cleaned them well, regreased and problem solved. Great product and my mileage has gone up 2-3 mpg since putting them on so well worth if it you're putting any kind of mileage on your rig.
  2. Nice videos! Actually doesn't look too much worse than when I use to go up there, but your guys 6" lift makes it look a little less severe than in my stock jeep!
  3. I just did two trips in one day pulling a 6x12 open uhaul trailer about 20 miles one way and had zero issues with my 98. As long as the trailer has breaks it's not a big deal, just takes longer to get up to speed. I didn't even notice it was back there once i got up to speed and stopping was no problem either with the brakes on the uhaul trailer. I had 2 fridges, a couch (with foldaway bed), 2 dressers, a wine fridge, and boxes of misc stuff (half of them full of books). And the back of the pathy was filled completely, So I'd guess I was over the 3500lb tow rating but had no problems. Backing it up my brother's driveway where it was pretty steep, she sputtered a little but that could be because of my clutch and tranny going out.
  4. I grew up in Buena Vista and have driven up all those roads. Pretty drive and fun 4 wheeling. Lots of pucker places up there too with some of the roads going across rock slides with the first stopping place if you went off being a couple hundred feet down the hill. Those switch backs are super tight too, I'd have to do a 3 point turn to get around some of them in my jeep comanche! Someday I'll get back up there and do those trails again. Last time I went to Grizzly lake was to go fishing and remember blowing a tire halfway up that section you're speaking of. Not fun changing out a tire on that! That section of road was tricky but definitely wasn't a 6 rated obstacle 10 years ago but got worse every time I've ever been up there so I can believe that it's probably pretty bad now. Can't wait to see more pictures of that area though!
  5. It's the main gear in the transmission... if you don't have enough oil in there or don't change your oil and loose the proper lubrication you scortch (I know that's not the right word) the gear and it whines. The only fix is a complete rebuild including the gear or just finding a nice used one which I'm looking at doing because it's cheaper than rebuilding.
  6. Yeah... definately make sure the maintance has been done regularly... mine just hit 170k miles the manual tranny has got a serious whine (death whine), the thing overheats if I run the a/c for longer than 5 minutes, struts are blown in the front, the clutch is slipping. So I am contimplating cubing it because I don't know if it's worth the $1500 in parts I know I need to get it fixed to run another 100k miles. But that being said, if it has been taken care of these things are beasts. Even with these problems it did better this last weekend pulling an open top 6x12 trailer packed full of probably 3k lbs of dressers, fridges, and the such than my brothers newish jeep comander pulling a 4x6 puny trailer with maybe 500 lbs of stuff. So I am not here to discourange anyone from the R50's becasue they are a good vehicle, just don't buy a car off your parents who were the origanal owners that didn't do much beyond change the oil every 3k miles then let my wanna be nascar style big city driver of a brother borrow it for a couple of years and not maintain and abuse it. Most of the stuff going bad I can attribute to his crappy driving and not to the pathfinder being a crappy SUV since the clutch and struts were both replaces less than 40k miles ago...
  7. Okay after talking to a buddy who owned a driveline shop he says my trans is toast and on it's way out. Now here's my question, what is the difference between all the years of wd21, and r50 manual transmissions besides the fill hole? I'm just seeing what my options are for replacement. Oh and my wheel bearing is in tight, looks like the control arm bushing is done causing the play in the wheel.
  8. Hey thanks for the help, I'll hae to see what's going on and take everything apart again. I just got some warn hubs a few months ago and they worked fine and engage and disengage. The fluid out of the transfer case looked good, the diff, again like pepsi. I didn't see any metal shavings or anything like that out of either, a little on the magnets but nothing to throw up red flags. There isn't much play in teh wheel bearings wither, if you pull on the wheel it might move 1/8". The front seems to be only bind on one side at a time not together. Hopefully I can get some poking around done and figure all this out.
  9. Yeah I'll have to shop around for sure. Read the TSB and saw it wasn't for me but figured I'd still overfill a little just to be safe, figured if it's too much it'll spit it out the top. Seperate but similar question. I'm realizing that my drivetrain is crapping out on me, and when I lock my hubs now it feels and looks like things are haning up in teh front diff so it's making a crazy vibration. When 4wd is engaged or not there is that vibration and if you spin the front wheels they spin like they should but then on stops while the other spins about 1/4 turn and then you can see the diff start to bind up. Is that screwed too or am I just just having a major brain fart. Figured I'd see if anyone has any ideas before I go pulling things off and taking them apart.
  10. sounds like a plan to me, I guess the search for a replacement trany begins. Anyone know if there is somewhere that states the cross compatibility of the models and generations. I have an early 98 so will any R50 work? from my little bit of research it looks like they may be different 96-98 and 98-01 but want to clarify. I'm sure it doesn't help that I've had this for 10k miles and didn't realize that the fluid had probably never been changed and looked like pepsi with chocolate milk swirls.
  11. Well just realized it doesn't make that noise in 4th gear... damn it!
  12. My clutch sounds like it's slipping but only when I first start it after it's been sitting overnight or longer. But lately I have been hearing a whining, like when you're in reverse but when I'm going forward and it's a lot louder when I get on the gas over 2500RPM. I'm haven't really ever missed with a transmission/clutch since I've never had any problems with anything I've owned in that area so I have no idea what is going on. I swapped the tranny fluid thinking maybe it was low, well it wasn't but it was black since I don't think anyones changed it ever (160k miles). It looked like someone had tried to change it, partially stripped the fill plug and said screw it. So all that being said, it makes taht whine when the clutch is disengaged and you're parked so I crawled under there while it was running and it's definitely coming from the front of the transmission around the clutch area. The noise goes away completely when the clutch is in though. So would this be a bearing, the clutch, something else I'm not aware of? Thanks
  13. I am officailly accetping defeat, not normal for me but I'm out fo gas in my welder, the damn thing won't even so much as budge so I guess we'll see if a shop can get it off for me. Dang.
  14. yeah the 1/2 in drive on the inside, not the threads. I'm not the best at describing things so other people know what I'm talking about (at least that's waht the wife says)...
  15. Anyone have a trick on how to get a fill plug out that has the [] on the inside of the plug partially stripped? It's stuck in there good and looks like the PO had maybe tried to change the fluids and stripped it a little. I can still get some bite, just don't want to risk stripping it completely.
